- nevadanickExplorerDirtyoil, i think your conditions are similar to ours. I had a couple 1/2 ton trucks for salesmen that M55's went 90,000mi. On the heavier trucks 50,000 was the best we could get. Any other brand was 30,000 tops. Lots of gravel/dirt roads and high speeds are the norm here.
- HannibalExplorerThanks for the heads up. I almost went with Toyo for our F250 last year at the recommendation of the tire shop. Went with the Firestone TransForce instead at the recommendation of the good folks here. No regrets.
- DirtyOilExplorer
Dirtyoil, your the first person i have ever heard that had a problem with M55's. There are more of those on trucks around here than any other tire. I have worn out several sets myself without issue. Did you take them back to the tire dlr ?
Yes I did, dlr tried to tell me it was a weight thing... too much!? LOL, went to another dlr had them put in the paper work. Got a rebate from Toyo which I used to purchase General Grabbers. The roads I travel/work on, allow me to wear tires out faster then most. So, I get to "test" the different tires. I did like how the tread was wearing on the M55s, far better then BFG, better then Cooper SST, Dick Cepek FCII, and tenfold better then Dunlaughs. We'll see how the Generals work out. Thinking there might have been a bad batch of M55s that I received. Only 3 of the four showed the splitting/cracking. As you pointed out, lots of users, that was the reason I went to them in the first place. A lot of guys running M55s up here, reports of long lasting tread and weight capacity, good traction in both mud and snow/ice. - nevadanickExplorerDirtyoil, your the first person i have ever heard that had a problem with M55's. There are more of those on trucks around here than any other tire. I have worn out several sets myself without issue. Did you take them back to the tire dlr ?
- Garry_GayleExplorer
FishOnOne wrote:
Thanks for posting for others to be aware of... I almost pulled the trigger on the Toyos last year and while doing some research I found out where these tires are made. After that the Toyos came off the short list.
You can choose where they are made Japan, USA or China they have plants in all 3 countries and did you notice it's a voluntary recall, speaks a lot to me - DirtyOilExploreryou wouldn't have liked them anyways Fish... terrible tires just replaced Toyo M-55s on my Ram... the tread was wearing very well, but it was the sidewalls near where the tread meets the sidewall was cracking and splitting. The splitting looked like someone took a knife to them. Had less then 30,000km on them. Says a lot about a supposed "commercial" rated tire!
- Thanks for posting for others to be aware of... I almost pulled the trigger on the Toyos last year and while doing some research I found out where these tires are made. After that the Toyos came off the short list.
- ScottGNomadTo save everyone from having to look, it effects Toyo Open Country H/T and Nitto Dura Grappler Highway Terrain tires.
The specific runs of tires being recalled are:
Toyo Open Country H/T with Tuff Duty:
Size LT235/85R16 120Q E/10 — DOT CX 9JF41 5108 through CX 9JF41 4211 and N3 9JF41 2010 through N3 9JF41 2713;
Size LT245/75R16 120R E/10 — DOT CX A3F1E 4408 through CX A3F1E 4211 and DOT N3 A3F1E 2310 through N3 A3F1E 2513;
Size LT265/75R16 123Q E/10 — DOT CX LTF31 4908 through CX LTF31 4211 and DOT N3 LTF31 4210 through N3 LTF31 1012;
Size LT285/75R16 126Q E/10 — DOT CX LFF42 5108 through CX LFF42 4211;
Size LT265/70R17 121R E/10; DOT CX 7KF43 0109 through CX 7KF43 4211 and DOT N3 7KF43 4710 through DOT N3 7KF43 0812;
Size LT225/75R17 116Q E/10 — DOT CX DXKAM 0210 through CX DXKAM 1112; and
Size LT235/80R17 120R E/10; DOT CX A0LCC 2111 through CX A0LCC 4411.
Nitto Dura Grappler Highway Terrain:
Size LT275/65R18 123Q E/10 — DOT CX BWEAW 3307 through CX BWEAW 4211;
Size LT265/70R17 121Q E/10 — DOT CX 7KEFA 2907 through CX 7KEFA 4211 and DOT N3 7KEFA 4710 through DOT N3 7KEFA 2012;
Size LT265/75R16 123Q E/10 — DOT CX LTEAW 2207 through CX LTEAW 4211 and DOT N3 LTEAW 4610 through N3 LTEAW 0912; and
Size LT245/75R17 121Q E/10 — DOT CX BXEFA 2507 through CX BXEFA 4211 and DOT N3 BXEFA 4310 through DOT N3 BXEFA 1812.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
