Trailer bearings maintenance
vandave
Needing to have my 30u bearings packed. Packed them three years ago and haven't towed the trailer more than 1,000 miles. Wife at the last minute wants to visit daughter who lives 700 miles north and with a bump arm I can't do it myself. Does any one know of a decent place to have them serviced in 50 miles radius of dayton, Ohio? Thanks for any and all feed back.
Vanda and Dave Ludwig (Vandave) Spoiled King Charles Spaniel, Ultra spoiled Cock-a-Poo
9 REPLIES 9
Lynnmor
Huntindog wrote:
jfkmk wrote:
I would think any auto repair shop would be able to repack the bearings.
The actual packing of the bearings with grease is the same on just about all bearings. But the methods of getting the proper adjustment will vary.
Nah, they are all just bearings. They all are adjusted with a minimum amount of clearance.
OP, if work was done correctly you are good to go.
vandave
Thank you for the replies. We did head out and 2400 miles later no problems. I did check the temperature with a heat gun at stops and no significant temperatures. And $50 per axle is the going price. With the big trip over, I might just do them myself since I have an extra set of grease seals.
Aluminum_Siding
I think you'll be fine without also. I don't know any shops around there. For what it's worth the shop by my house wanted $50 per wheel.
Huntindog
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
jfkmk
skipnchar
Unless you have signs of a big time grease leak your bearings should be fine. I agree with others about "go and enjoy yourself". I repack my bearings about every 30,000 towing miles.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
rskrbina
dave17352 wrote:
I would head out without repacking. With only a thousand miles on a repack I would think you would be more than fine. I do mine every three years or so and travel probable 10k on them before repacking. MHO
X2. Dave has it right. Should just pack up and go. Safe travels
Rudy, Jenny and Garrett
2014 Thor.. Four Winds 35SK Super C..F-550..6.7 Diesel
CRV, F-150 & Wrangler Sahara Toads..TST Tire monitor
midnightsadie
I
dave17352
I would head out without repacking. With only a thousand miles on a repack I would think you would be more than fine. I do mine every three years or so and travel probable 10k on them before repacking. JMHO
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
