Trailer Weight Explained
augustpilot
Followed Rons weight guide posted a couple of years ago. Got 3 weights, truck alone, trailer hooked up with w/d bars hooked, trailer hooked up bars off. These are the weights. the trailer weights are 8100#, tongue weight is 1050#, load transferred with w/d bars amounts to 20#. The 1500 Dodge Ram goes down about 1 1/2 inch. I had the Firestone airbags with 10lbs of air.
2017 Rockwood 2906WS Ultra Light
2014 Dodge Ram 1500 5.7. 4x4
Firestone Air Lift 1000, Equalizer Hitch
7 REPLIES 7
augustpilot
It squats about 1 1/2 inch. Airbags have 10 lbs each. Talked to equalizer hitch co in Salt Lake. Told him what last shop did to hitch. They took out washers, only three now and the equalizer bars are not doing much. Tech in salt lake said it should have at least 5 washer so that would put a lot of pressure on the stabilizer bars. Am taking back to a different shop, hope they can fix. Should be a lot more than 20 lbs transferred.
bguy
How much does it squat without the air bags?
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
apr67
APT wrote:
I suspect if you have 8000 pound TT with over 1000 pounds of TW, your front axle lost about 400 pounds. You'll want to restore all of that, which will transfer closer to 200 pounds to the TT axles.
Yeah, we need more data. I read that as the front is 20# heavier than unloaded..
2017 Thor Hurricane 34J
Gone-2014 Chevy Express 3500
Gone-2016 Jayco White Hawk 32DSBH
Gone-2013 Keystone Bullet 294BHS
Gone-2007 National SurfSide 34DE
Gone-2006 ForestRiver Sunseeker 2900LTD
Gone-1994 Fleetwood PaceArrow
Gone-1978 Kit RoadRanger
APT
2017 Subaru Outback 3.6R
LarryJM
Lspangler wrote:
Can you post front axle, rear axle and trailer weights in all three scenarios? Also include a photo of the yellow sticker in your door jam
20# transferred is no where near enough and depending on what you and your family weigh your ram 1500 may be over payload ratings. My 2014 ram 1500 had a 1220 lb payload rating so with your trailer one adult would max out the truck!!
Linc
Yep something doesn't make sense:h and so much for the "EXPLAINED" proclamation:S in the thread title.:E
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
TucsonJim
From your subject line, I thought you were going to make it simple like this:
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Lspangler
Linc
