Fnp5150's avatar
Fnp5150
Transmission cooler
I'm new to the RV life and am concerned over the need for a transmission cooler. I will be towing a 26 foot Jayfeather weighing 5050lbs fully loaded, 4500lbs dry. My tow vehicle will be a 2007 Expedition with 5.4 motor. It's tow rated at 6000lbs. without the towing package and 8500lbs. with the package. Mine doesn't have it. I'm not too concerned about the engines ability to pull it, but since I'm close to the 6000lbs should I worry about burning up my transmission and install a cooler? This would have been standard with the tow package. I do live in South Georgia where it gets HOT. Will be traveling with 2 adults and 3 kids under age 10. Would synthetic transmission fluid help also? I've only pulled it about 20 miles from the dealer and the transmission temp did go up just a little, and I had overdrive turned off.
