FredoTT
Jan 25, 2018Explorer
Travel Trailer Tires
I have a 1 yr old 26' travel trailer with 75 R14's (dual axel). They seem small (and low end). I want to upgrade to R15's. What is considered the best travel trailer tire?
gmw photos wrote:
Before you try to upsize, you need to determine whether you have the clearance above the tires. For instance, my travel trailer does not have room to switch to a larger diameter tire. It would rub the bottom of the trailer when the suspension flexed to full travel.
If you can go to 15", I second the recco of GoodYear Wrangler HT, "LT" tires. I run them on one of my horse trailers. It's a good tire.
