travel trailers
rmgozia
Novice - Need to know what size equalizer hitch to buy. the trailer I am buying has a tongue weight of 580 lbs.
20 REPLIES 20
downtheroad
Agree, those are unusual specs.
But, that aside...given those numbers, I agree with SoundGuy. I'd order a hitch with 1000 lb. spring bars.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
MFL
Nomad II
Nomad II
X2 Very unusual trailer specs!
Jerry
SoundGuy
rmgozia wrote:
Gross Trailer Weight Rating 7580
Trailer Dry Weight 3472
Carrying Capacity 4108
Hitch Dry Weight 580
Would not expect to carry more than 1000 lbs. in trailer at the most.+
Hmmmmm, unusual. Sure would like to know exactly which make / model / year of trailer you're talking about as it would be pretty unusual for any trailer with such a low UVW to feature such a massive CCC AND also have such a high unloaded gross tongue weight to UVW of almost 17%. :h
All that said, if you're sure you want an Equal-i-zer and you're sure gross tongue weight of this trailer loaded and ready to camp will regularly exceed 600 lbs then you'd want to go to the next size up EQ - the 1,000 / 10,000 lb model.
2012 Silverado 1500 Crew Cab
RandACampin
If your buying new the dealer will set you up with a hitch and sway control.
HEY CHECK IT OUT!! http://www.rvingoutpost.com
rmgozia
downtheroad
That is probably the "dry" tongue weight....could you post the GVWR (gross vehicle weight rating) of the trailer....then we help you with the correct size hitch spring bars you are asking about...
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
