ngiovas
Aug 09, 2021Explorer
enblethen wrote:
Does it have a battery?
Have you checked for 120 volts AC to the 12 volt DC converter?
Check for 12 volts DC leaving converter. Could be bad converter or if your lucky blown fuse in 12 Volt DC distribution panel.
Thanks for the suggestions. I will check all of the voltages when I return. I did check the fuses and they were all good. There are 4 12v lighting circuits, so if it was a fuse issue, it would lilely only affect one circuit. Plus, I was getting some power since the lights were dim (and occasionally fully on).
There is a battery that was fully charged, but it didn't seem to change anything if it was on or off.
I wonder if I can disconnect the converter and try to run off of just the battery. If I still have the issue, it may be a ground issue.
44,026 PostsLatest Activity: Mar 01, 2025
