Truck alternators
mt-ed
I've noticed that truck manufactures offer alternators with different outputs. Can anyone please explain to me why a truck owner might want, or have the need, for an alternator that has these higher outputs? I'm assuming there is some need for it, but exactly what might these needs be?
Thank you very much for your help.
21 REPLIES 21
GAR2
To the OP, I see and understand your original post was “options from the manufacturer” which in that case, engineering has been done. But there are an awful lot of people throwing h.o. alternators on older trucks—- I guess my comments are just precautionary for those thinking about aftermarket products 🙂
In the market to buy a T/C
2002 F350 4wd CC DRW 8’ box
Load Lifter 5000 rear air bags, front Timbrens
Rancho 9000 shocks
Brighton, Illinois
GAR2
At first glance the concept of replacing the OEM alternator with a large, high output unit would seem like a good idea...........at first, at least with my particular truck. I have added a large (17,500#) winch and did a lot of research on the topic. As it turns out, if you own a 7.3L PSD, adding a high output alternator could actually shorten the life of your glow plugs which are designed for 11 volts. You can do a search as there has been a lot written on the subject. Secondly, most of the manufacturers who make or sell the h.o. alternators recommend upgrading to larger cable from the alternator to the battery(s). As it turns out, with my diesel having dual batteries, I simply set my tuner to high idle (which also gives you more amps as output is based on rpm’s) rather than idle and have not had an issue with enough reserve power to run the winch at it’s rated duty cycle. Same thing with my inverter for camping- I simply set the tune to high idle if I’m running a heavy load. Obviously, everyone has a different rig / motor, but there’s more to consider when significantly increasing amperage output well over the manufactures specs. Good Luck!
Rancho 9000 shocks
Brighton, Illinois
Lwiddis
“Also, some trucks have an optional built in inverter to power a 120 volt a/c power outlet.“
Two are standard on my new Silverado LTZ, Optomistic.
mi_drew
Well said bwlyon. Very accurate response.
Optimistic_Para
Also, some trucks have an optional built in inverter to power a 120 volt a/c power outlet. I would assume that option would require the higher amp alternators.
Kayteg1
Another need for high amp is electric cabin heater some vehicles have.
In my Ford Truck the option forced me to get dual alternators.
In my Sprinter van I have single 250 amp alternator.
I still remember older diesel pusher with 60 amp alternators doing just fine.
bwlyon
The need for extra alternator output comes with people who run snow plows that have extra lights to run as well as power the electric over hydraulic lift for the plow. Overlanders use the extra alternator output to run electric air compressors, winches, and other electrical accessories. The thing to remember is that the battery in the car is a power reservoir used to start the car not run other electronics. The alternator is what runs the electrical components in any vehicle, and top of the battery after it has been used to start the engine. When you start running aftermarket accessories you can easily use all the alternator’s capacity and drain the battery, hence the need for an alternator with a larger output.
