Jeepers92
Dec 29, 2014Explorer
Truck Campers 10 years from now?
Being close to the new year, was just wondering what kind of camper our children might be driving ....
I can see them being much more " Off Grid ", than what we have now. Using newer designed photo cells to charge nickle metal battery packs controlled by an on board central computer system. Think of a battery system 1/2 the size, and 4 times the capacity of our current best spiral batteries.
How about smaller generators running on a fuel cell, also tied to the central computer system. It would automatically sense all power use and charge, making the best choices for you. It would also sense propane usage, auto tune your TV, be your radio, weather station, Co2 monitor,etc...and provide this info to a small touch pad monitor.
Flexible plastic outer bodies with an integrated aluminum frame, 2 or 3 slides, using a hydraulic system. The slides would sealed with accordion silicone seals to reduce leaks. How about the opposing slides to one track for counter balance.
All the outside to inside outlets ( AC, vents, etc.), would be sealed with ridge type aluminum seals requiring no sealant and all accessable from the outside.
The black water system would contain a compaction system, and dry disposal to reduce requirements on the black tank. How about a system to take the gray water and use it to supply the commode?
A water system that would collect rain, dew, exc.
Oh well, enough musing. My spring project is rebuilding the nose on my Fox.
