Truck floating in front of travel trailer
danv1317
I may be able to answer my own question, but just want confirmation.
I have a 29ft Springdale travel trailer that i was pulling with a 2wd dodge ram 2500 5.9L.
Since we stopped full timing, we got rid of the diesel and got a 2014 Ford F150 3.5L ecoboost. It's 4wd so it sits higher. To add some xtra umph to the suspension on it, i put on the Roadmaster Active Suspension.
I didn't change the height of the ball on the weight distribution hitch so it's still set for the dodge which was 2wd (lower to the ground) and didn't accomidate for the extra inch lift you get putting the active suspension on.
Driving down the highway today getting hte trailer fixed, the Ford feels like it's floating on clouds. Even at 30mph, it feels like i'm driving on snow, floating back and forth. I do have weight distribution hitch and sway bar.
I measured the front and rear of the trailer and the top of the ball is 2 inches higher than the rear of the trailer, so it does squat slightly.
Am i putting too much weight in the rear end?
Also, the truck isn't squatting really at all with the trailer on. Is this correct?
Thanks for the reassurance that i need to lower the ball if that is the case, if not, i appreciate any input. I know my TV is probably a bit overweighted, since i'm sure a lot of you will reiterate that to me.
31 REPLIES 31
Mike_Up
danv1317 wrote:
I've had 2 Crew Cab 4WD F150s like yours, a 2010 with a 5.4L and a 2012 with a 5.0L, and now a new generation 2016 Crew Cab 4WD with another 5.0L. I pull a stick and tin 2012 Jayco Jay Flight 26BH which is 29' bumper to hitch.
I see 2 problems with your setup. First is that weight distribution hitch is setup incorrectly and you're nose high which will cause porposing and will cause the trailer to be unstable.
2nd, unless you're towing that trailer with just you in it, you've probably overloaded your truck. Both my F150s of that generation had lower payload. That's one long trailer with a very heavy slide and heavy stick and tin build.
And while I can't see it, with that huge trailer, you definitely need some LT tires and not the standard P series tires that come with a F150. The P series tires are soft and will cause your rig to wallow back and forth and feel unstable.
Old hitch on new truck. Bounced and was unstable the entire way to the camper dealer. Reese straight line dual cam system proved not to work correctly on new 2016 due to it's omission of 1000 lbs bars.
New Blue Ox Sway Pro hitch for new 2016 F150. Adjusted correctly if not somewhat low. Rides very good and stable now. I did adjust 1 link tighter to get the rear up a bit more which proved to offer a better tow experience.
Good luck in making that rig work.
2019 Ford F150 XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 9.75" Locking Axle, Max Tow, 1831# Payload, 10700# Tow Rating, pulling a 2020 Rockwood Premier 2716g, with a 14' box. Previous 2012 Jayco Jay Flight 26BH.
Hannibal
Our F250 was solid as a rock with it's well worn Firestone TransForce HT's towing our 32.5' TT. I had new Firestones installed before our Christmas trip. I was expecting some tread squirm and got some. As said above, after about 1k miles, it settled down. Until then, the constant minor steering corrections were a bit tiring.
I second resetting the hitch. Trailer needs to be level or slightly nose down. And never lighten the tongue to accommodate a light tow vehicle.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
CampingN_C_
Hard to tell in the pic, do you have any sway control or just a standard WD hitch.
If not, and it doesn't look like it, you may want to consider adding the Reese Dual Cam to your existing hitch.
2018 Ram 3500 DRW CCLB Aisin 4.10 4x4
2018 Jayco Talon 413T
B&W Companion
GaryWT
Once you lower the ball and get more weight on the front tires of the truck with the hitch it will be better but might never be perfect.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
Camper_G
I cannot add anything to this conversation other than what others have said, the nose the travel trailer should be slightly lower than the rear or at least level, get that squared away and then go from there
2017 Dodge Ram 2500 HD, 4x4, CCSB, 6.4L HEMI, Snow Chief, tow package.,1989 Skyline Layton model 75-2251.
1stgenfarmboy
I know this has been talked about a few times, when I replace the tires on my dually and hook up the goosneck farm trailer it feels like I am going to die, it is the worst feeling ever the way it walks all over the road, it really feels like the rear end U bolts are loose, but after a few thousand miles it settles in and all is good.
the tires were Geolanders for the record.
1993 Dodge W350 Cummins with all the goodies
2014 Ram 1500 Laramie Longhorn 2wd 395hp
2017 Forest River Surveyor 243 RBS
2001 Super Sherpa & 2012 DL650A go along also
RPreeb
As others have said, towing nose up is a no-no. Should be level or slightly nose down on the TT. Need to change the hitch ball setup to lower it. We had to buy a new adjustable height ball mount when we went from a Honda Ridgeline to the F-150. The Honda was AWD, but not nearly as tall in the rear end as the Ford.
Rick
2016 F-150 XLT 4x4 3.5 EB
2017 Jay Feather X213
old_guy
looks to me like you just bought a new truck and hooked up without trying to match the hitch and tt to the truck. you need to tear down the hitch and set it up properly to this truck. once you do that go for a drive and reevaluate the system again
drsteve
Get it so the nose is about an inch lower than the rear, and go from there. You'll probably find that with a little adjustment, the tow is just fine.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
coolmom42
ford truck guy wrote:
My bro in law had the same issue... turns out that it was caused by the new tires that were on the truck.. they rubber was soft, and the tread was high,, that gave the treads room to flex a bit and gave him the feeling of floating.. after about 1,000 miles, that all went away...
Not to say its your problem......
I agree, I've had this problem with new tires too. But check the other stuff first.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
rbpru
I believe you have heard the two most obvious comments. New truck new setup and an F-150 is not going to tow like a 2500.
You have a lighter truck, with tires, suspension and other options designed for a softer ride.
That said, we love our E-boost F-150 but then we might like an F-250 even more.
Keep us posted.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
SouthpawHD
Likely some issues with the WDH and sounds like you are going to address that.
But let's look at something a little more basic than that. You've been driving around in an older and heavier 3/4 ton truck. Now you're in a newer and lighter 1/2 ton with a better suspension. Perhaps you're just not used to that feeling of now it rides. In some respects it's almost like a bus compared to a Caddy. Just a thought.
Palomino SolAire 307QBDSK
2016 Chevrolet 2500, CC, 6.0L, 4.10
trail-explorer
You answered your own question before even asking the question, all in the quote above.
Bob
