Thunderbolt
Sep 21, 2021Explorer
Truck not getting fuel
My 03 Silverado 2500HD 6.0 liter is having fuel issues and I am looking for some input before towing it to a shop. I was driving home from the lake with boat in tow a week ago and the truck coughed and died in the middle of an intersection. It was not getting fuel and had it towed home. I had a new pump at home so I put it in. This was just the pump and not the whole module. The truck still did not start right away, but eventually did and ran fine so I drove it all week without issue. On Saturday I was 100 miles from home and it happened again.
No security light on and I tried swapping the relay and that was a no go so it was towed the 100 miles home. I have been doing some reading about the connectors on the original fuel pump housing failing or causing issues so I am thinking that could be the issue. Before I put a whole new assembly in I thought I would reach out and see if anyone has any ideas. Would a failing plug randomly quit working ? I know unplugging it and plugging it back in could possibly be why the truck ran after the new pump.
I have also not ruled out the Passlock security even though the security light is not on. I have tried the passlock relearn procedure several times with no luck. My plan is to lower the tank enough to get at the connector and see if power is getting to the pump. Any other suggestions before I have a shop fix it ? Sorry so long winded, but I wanted to give as much detail as possible.
