โDec-13-2017 06:39 AM
โDec-13-2017 09:25 AM
โDec-13-2017 09:19 AM
โDec-13-2017 09:13 AM
donn0128 wrote:
A 2500 series truck, especially the newest ones give up nothing in creature or ride comforts. The newest gas motors are vastly improved in power and fuel economy. You also gain hugh in towing/load carrying ability. Unless you are planning in the near future to upgrade to a much larger TT of possibly a fifth wheel you probably dont need a 3500 or a diesel.
โDec-13-2017 09:07 AM
โDec-13-2017 08:02 AM
silverfz wrote:
My truck is at 135k and I am thinking in a year or so I will be needing another truck or not. Not sure as this is my first truck so far all the cars i have had, i sold them around 100-120k.
Trucks (real) are designed to work. So 100K to 120K is nothing...if it is taken care of
Even today's cars are good for more and...if it is taken care of
Min of using the manual maintenance schedule and better if using the higher level schedule
1) I take good care of the truck. It tows 2k a year and used as a grocery and school trips for 10k a year.
Your truck should go a loooong time with this non-truck usage
2) I have airbags in the rear I run at 20 PSI and equalizer 4 pt hitch.
3) I also update the rear shock to 4600HD.
4) I sold the camper by dealer with the statement it will tow easily but nope. It took airbags and shock to be solid.
For you trailer...your TV is at the limits and/or over and you have compensated with all this stuff
Nothing wrong, but know it is at or over the ratings
Note that all things designed...have a specification. AKA ratings. and that is the CYA for the OEM. Proof of being over their ratings is tough to prove, so generally...most are not caught on that after an accident...that day Mr Murphy crosses your path
Should I go to LT tires?. Will it improve the towing experience. It already perfect as long as I air up the tire to 40 PSI rear. But just a question?
I am at or above payload now on the tundra crewmax . Will a more payload vehicle improve the experience?
All of your mod's are to try and move your TV's ratings up into tyhe next class.
Going to LT class tires (next higher class over 'P' class...passenger class). Some Tundra's do come with LT's, but not all or enough...it is still a half ton
40 PSI is on the high end and again upping the spring system, but not the frame/suspension/etc
The 5.7 V8 with a full custom exhaust just pulls great but i get bad gas mpg at 7-8 mpg. Will i improvement.? With 20 gallon tank to get gas light i am limited to 140-160 mile range now .
Laws of physics, as to move that approx 32 foot, 8,000 lb trailer takes the same amount, generally, from any TV. Whether small block/big block gasser or diesel.
Of course factored by several. Like pumping loses, frontal air profile, etc, etc
I want to start researching and test drive some trucks. My current rv is 7k-7.5k loaded depending on length of trip.My payload is 1400 and i usually do not carry anything in the bed due to it being so low.
Low mileage Used
Titan 5.6 with 1800 lbs
F150 PayLoad Package
or
Put LT tires on tundra and just ride it will an rv upgrade or it breaks down enough to warrant a change.
or
F250 gas - as my vehicle. I work from home so really it will be MY vehicle and wife will keep the tundra.
You will get tons of advice and mine is only to provide you with enough info to make your own decision
Here is the generic formula suggest you find info for and use to derive your next TV
GCWR >/= actual weights of TV + Trailer + stuff (people, hitch, cargo, pets, etc, etc)
