โNov-18-2022 10:28 PM
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLSโNov-29-2022 09:36 AM
Grit dog wrote:toedtoes wrote:Busdriver wrote:
Talked to my service writer, he said there is no way to disable auto start on a 2019, said that feature was started 2022. Said probably a wifi signal close to my house
If that's true then I'd put in a battery disconnect switch. No battery, no start.
Great solution for a 1975 RV.
Not a great solution for a new car / daily driver.
โNov-29-2022 08:28 AM
โNov-29-2022 06:11 AM
rhagfo wrote:opnspaces wrote:Busdriver wrote:
Last night was watching tv heard my truck start . Went into my garage truck was running all lights on dashboard was flashing, Has anyone else had this to happen? The key was off
2019 Duramax. 2500 HD 80 thousand miles
Going back to your original post. It might have been asked but never answered. Do the dash lights all flash if you use your remote and start the truck?
If yes the dash lights all flash I would suspect you accidentally started it with the keys in your pocket.
If no the dash lights do not all flash then I would go back to the dealer with it as something is not right.
Actually Busdriver hasnโt answered the question as to where the key fob were when the truck started on its own. The signals from the key fobs are coded so likely accidentally tapped the fob in the pocket.
Someone mentioned leaving to hood open, I had a failure to remotely start the other day I had put some stuff in the back seat, and had not gotten the door fully closed. I do know that if not all doors are fully closed when driving, not only do I get the little icon on the instrument panel, also the interior lights stay on. Not sure if they would time out if truck not running.
โNov-29-2022 06:06 AM
โNov-28-2022 10:01 PM
โNov-28-2022 01:14 PM
โNov-28-2022 11:43 AM
โNov-28-2022 11:20 AM
โNov-28-2022 10:36 AM
mkirsch wrote:
Make sure you get that in writing from the service writer, so your next of kin can use it as evidence when your truck starts again in the garage in the middle of the night, you don't notice it, and it fills the house with CO.
Be very plain with the service writer that this is a very dangerous situation, and that his answer is not acceptable.
โNov-28-2022 07:12 AM
Busdriver
2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLSโNov-28-2022 06:23 AM
โNov-27-2022 01:31 PM
โNov-25-2022 04:37 AM
โNov-25-2022 01:14 AM
โNov-24-2022 07:32 PM
PastorCharlie wrote:
Probably neighbors have remote start for their vehicles.
Like house keys, one key fits many houses....Many devises use the same frequency.
