A 7.00x15 tire has a nominal casing width of 7 inches. Most modern tires measure the width in millimeters. So 7.00 inches = 171.5 mm - but the 7.00 is a "nominal" measurement and isn't really measuring the same thing as the 7.00. Figuring all that, keeping in mind each tire model will have slightly different dimensions, a 7.00x15 is approx. equal to a 185/100R15 or a 195/92R15. Good luck finding that!!
A tire that is available that is about the same size is a 255/75R15. It is about one inch smaller in diameter, and one inch wider.
Another possibility is a radial 7.00. Yokohama has one.
TireRack linkI have never used that model, but I have run a lot of Yokohama tires over the years and have had good service out of them.
