Rwake901
May 31, 2021Explorer
Tuner like “5 Star Tune “
I have a 2019 3500 Silverado 6.0 gas. Has anyone used a tuner like a “5 star tune “ ? I was wondering if or how they work before I purchase one and which brand I should buy? Thanks
philh wrote:Jarlaxle wrote:
I saw a Charger that got a tuner on it (Diablosport Predator) before its first oil change.
The car is still running, 15 years and almost 400,000 miles later. The engine and transmission are internally untouched. I recall it turned 200,000 miles at over 100MPH and 300,000 miles enroute to a HPDE.
There was a guy years ago that did mobile tuning for the Dodge cars. He was leaving a wake of grenaded motors in his wake. As more and more people ended up with destroyed engines, people who dared issue negative comments were threatened with lawsuits, and IRC, there were a couple that got filed. His reputation eventually caught up with him and he went away.
As I said earlier, I won't use a tuner on a truck that is pulling a trailer. OEM's spend millions and millions making sure they calibrate for ALL atmospheric conditions. Tuners typically override built in safety margins.
dodge guy wrote:jerem0621 wrote:
I’ve got a blown 2.0 Ecoboost sitting in my garage that my son “tuned”. Broke the piston.
My advice for what it’s worth is don’t tune it unless you are willing to do an out of warranty engine replacement.
Jeremiah
The eco boost engine does not like to be tuned when done improperly!
Jeremiah
mkirsch wrote:Devo the dog wrote:mkirsch wrote:
Tuners won't do anything for engine output on a normally aspirated gas engine. That's already been maximized by the manufacturer.
All tuners do is give your subconscious a lead foot so you stomp on the pedal harder, say, "YEAH! I HAAAAAAVE THE POWERRRRRR!" to yourself, then find out three days later that nothing really changed and there's a hole in your wallet where several hundred dollars used to be.
Not true for regular vehicles.
Performance can be measured and the tunes increase HP and torque.
You get marginal increases at WIDE OPEN THROTTLE.
How often do you drive at WOT? Unless you're drag racing, almost never.
ls1mike wrote:
I have a 2017 6.0 3500HD, so basically your truck. I tried Diablew, he deals with the Diablo tuner. He can do a custom tune for you. You do some data logging and he adjust the truck based off it's specific parameters. It really woke my truck up, firmed up the shifts, removed some torque management and yes a tune like this or a dyno tune will add HP and torque. I am a fan of the Dyno tune 11 sec WS6 and a 12 second 14 Caprice they are dyno tuned, but the Diablew tune worked similar to a dyno tune and I am really happy with it.
The 6.0/6L90E tune from the factory is poo, it is really mild. I tend to believe his claims of 20 to 40 RWHP depending on the tune you get. It certainly holds the gears differently and makes use of all the power.
DiabLew
