Golfcart wrote:
Turtle n Peeps wrote:
In fact you get less power to the road; not more. The only thing a higher gear ratio will give you is more torque to the road.
You dont "get" less power. it just requires less power to accomplish the task
See what I mean. :R It requires the exact same amount of power to do a job no matter what gears you have.
Tell you what. You put a vehicle on a chassis dyno with 4:56's in it and make a pull. Then put 3:00's in the rear end and make a pull. See what makes more horsepower to the wheels.
Since it pretty impractical to change rear end gears to do this I will let you cheat and just make a pull in 1 gear on a chassis dyno and then make the pull in the gear closest to 1 to 1. See what makes more horsepower.
Get back to me and let me know.
