dee74 wrote:
westend wrote:
What I did was install the TV mount onto a piece of finished plywood and glue/screw the plywood onto the wall and into the studs.
This was my original plan but there is only one stud. The wall is actually a cabinet that holds the larger TV on the other side. The one stud runs through the cabinet and the larger TV is mounted to this stud on the other side.
You may get away with just installing the arm for the mount on just one stud. I think, though, if you can spread the weight out, you end up with a better support. Gluing a backerboard to the cabinet panel would accomplish that. If you can couple that with reinforcement between "studs" in the interior of the cabinet, you'll be golden.
FWIW, I don't remove my screen for travel so wanted a very sturdy installation. If you're looking for just a hanger for the screen while in camp, there can be a lot less thought into the plan. Also, the newer LED screens are light. IIRC, my 32" screen weighs 8 lbs.
