Cummins12V98 wrote:
"Well that is disappointing to hear about the Defenders. Chris "
Mine are labeled MS2's not Defenders. I know they are supposed to be the same.
Still disappointing on the mileage.
Briddgestone Dueler H/T 685 looks very similar to the Michelins.
I am going to stop at a FS/BS store today and pick their brains a bit on them. 50K mileage warranty seems good.
HEAVY-DUTY STEEL BELTS AND 2-PLY POLYESTER CONSTRUCTION
Engineered for towing and carrying heavy loads
WIDE GROOVES
Push water away from the tire, which helps reduce the risk of hydroplaning
SPECIALLY ENGINEERED TREAD DESIGN
Helps retain traction in snowy conditions to help you power through winter
NEW AND INNOVATIVE TREAD-TO-ROAD CONTACT FOOTPRINT
Allows the tire to adapt to the load and promote even wear
