โMay-20-2022 04:31 PM
โMay-22-2022 05:43 PM
โMay-22-2022 05:13 PM
โMay-22-2022 01:50 PM
โMay-22-2022 12:41 PM
โMay-22-2022 08:25 AM
โMay-21-2022 02:21 PM
โMay-21-2022 02:02 PM
BFL13 wrote:
Not sure this will prove anything, but here are photos taken the other day when on a site where I found the bubbles on the left back corner of the camper showed level both ways, without needing any blocks/ramps. (Bubbles set using a carpenter's level)
Truck has no air bags or extra springs. We got it new in Oct 2002. It drives ok. Been a while since new shocks. On scales with loaded camper, two people in cab, got:
Front- 1620 vs GAWR of 2041
Rear- 2450 vs GAWR of 2760
Total 4070 vs 4173 GVWR or (8954 vs 9200)
Empty truck 2720 so camper weighs 1350 (2970)
I will play with levelling it other ways in the back yard later on to see what happens.
โMay-21-2022 11:17 AM
โMay-21-2022 08:52 AM
JimK-NY wrote:
I does appear that there is something seriously wrong. First step would be to look at the rig on a hard, level surface. I suspect that will not fix the issue. Next step would be to determine the weight on each tire. I also doubt that is the cause. Next step, after visually inspecting the springs from every angle would be to take the truck to a spring/suspension shop and have it evaluated.
I am assuming you have already checked for the obvious such as a leaky airbag or and overload stop missing, broken, or incorrectly installed.
โMay-21-2022 08:50 AM
KD4UPL wrote:
By putting only one wheel up on a ramp you have twisted the frame. Once you put the wheel back down on the ground it will straighten back out.
I always leveled mine by using blocks under the truck wheels to get it as level as possible first. Then I used the camper jacks to tweak it and take some of the weight off the truck so it didn't bounce so much.
I had electric jacks, don't know about hydraulic. Maybe you can't use them like that.
โMay-21-2022 08:47 AM
joerg68 wrote:
Without knowing all the details, that looks like more twist than I would expect to see in this situation, with an older camper on a 2500 truck. When you move next time, get the rig on level ground and see how it all checks out.
It would not surprise me if there was an additional mechanical issue - e.g. a broken spring, or a bed mount or cab mount rusted out or broken.
Frame damage could also cause this, but I think that is unlikely. But then I don't know what the truck has been through during its lifetime.
โMay-21-2022 08:32 AM
โMay-21-2022 07:41 AM
โMay-21-2022 07:09 AM
โMay-21-2022 06:27 AM
