Under Trailer Spare Tire Bracket
Mister_Big
I recently move my spare tire from the rear bumper to under the front of the trailer because it was in the way of the bike rack and travel tray. I used unistrut which I purchased at home depot in the electrical section. I had to keep the unistrut close together as possible so there would be room to get the tire on the rack. I think most trailers have the room under the front to accomplish this.
2015 Skyline Koala 26SS
2004 GMC Yukon
Equalizer 10K Hitch
Prodigy P2 Brake Controller
Swagman Traveler XC 2 Bike Rack
15 REPLIES 15
TravelingTeache
We tried to order one from BAL, waited over 2 months with no luck. Hubby is now making it from scratch.
2003 Timberlodge Travel Trailer
2015 GMC Sierra 2500 HD Diesel
The Traveling Teacher
ArticFox_676
BAL makes a holder for a spare under your trailer. You drop it down and pull and the tire is right there. A little pricey but easy to use.
chr_
Yeah, I have the real estate for a truck spare carrier too. No LPG lines back there, But do I want to use the space for the tire or a gasoline tank for my new custom generator install...
-CHR$
1996 Safari Sahara Edition 35' Diesel Pusher. Just getting the Solar stuff started.
4x4Bob
Nice idea. However, I want to point out one potential problem not mentioned as of yet.
Your cross brace is tight up against the propane pipe. If any movement occurs with that cross brace it could cut into the propane line.
If it cuts through and a spark occurs, it could ruin you day. You might want to install a spacer of some sort between the brace the pipe.
Bob
2001 2500 Silverado LS 4x4 6.0, 4.10
2007 Jayco Eagle 288RLS
Cocktails for 6, Dinner for 4, Sleeps 2
End of dirt road, no signs in sight, sun going down: I am not lost, just getting ready to go camping.
PUCampin
This is a great idea! My TT is like yours, it has tons ground clearance and lots of real estate under the front 1/3 (holding tanks are to the rear). I could easily mount 1 or 2 under there and barely know they were there. I am adding it to my trailer project list!
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp = PUCampin! (Sold)
2006 Pioneer 180CK = (No more PUcampin!):B
Me:B DW:) and the 3 in 3 :E
DD:B 2006, DS 😛 2007, DD :C 2008
tkoden
I have been thinking about mounting one of these under the trailer right behind the axles so I don't have to worry about ground clearance.
ezrydrs
Nice work!
mbopp
I had a cable-type pickup truck spare tire hoist given to me, that may be another option. But I haven't felt the need to re-locate the spare.
2019 F250 XLT Supercab
Just DW & me......
Heap64
Sorry duplicate post.. I hate it when I do that.
James & Kim from Central Illinois
2012 Ford F250 XLT CC SB 4x4 6.7, ARE Topper and Decked Draw System
2013 Arctic Fox 25Y (1250lb tongue weight with mods)
Blue Ox Sway Pro 1500 w/Reese Titan Weight Dist Shank
Heap64
Thanks for the post. I have been thinking about getting mine off the rear bumper one way or another.
popeyemth
And it is a great solution no one is implying anything different
Just seein what MIGHT be a problem in a worst case situation .
Thanks for sharing 🙂
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
Mister_Big
It is easy to remove the tire from the bracket. All I have to do is remove the 2 nuts from the threaded rod u bolt that goes through the rim and slide it off to the side and it drops down. I made the u bolt that goes through the tire rim out of 1/4" threaded rod and I bent it to my specifications. Keeping the tire on the rear bumper was not an option. It was taking up valuable real estate. I could not find anyone that made a bracket for my situation. I understand it will be a little inconvenient getting at the tire when I have to. I am very happy with my solution.
2004 GMC Yukon
Equalizer 10K Hitch
midnightsadie
smear some water proof grease on those threads. might even put some plastic wrap around them, but looks like a good job. hope you never have to use it.
popeyemth
Keep an eye on those bolts they don't look plated and if they rust will cause plenty of aggravation on the side of the road in the rain-in the dark(when MY flats always happen 😞 )
