mrekim's avatar
mrekim
UniStrut clamped to I beam for under chassis storage
I've seen an expensive Lippert under chassis storage system ($700+) where the entire rig is held to the frame via 2 small diameter bolts drilled through the I beam flange on each side.
It seems like you could build a pretty flexible setup from unistrut without needing to drill at all. Below are two interesting mount options. There are lots more here.
Does this seem like a good base from which to build some under chassis storage?
