NorthernVandal's avatar
May 02, 2014
Awning clamps
Do you guys see a benefit to having dual clamps on each side for gusts? I have two wide clamps, one for each side, but seem to still get a bit of parachuting with gusts. Or is that too much tension? I may pick up another set if need be. It's a 15ft wide awning on my 19ft trailer. Thanks everyone.
  • When it gets that windy, I roll up the awning.
    "Better safe than sorry" :)
  • Clamps are ok but if it's that windy or the wind picks up fast your best just to bring your awning in and be safe.
  • If one clamp isn't enough, roll up your awning before it gets destroyed.
    Your manual probably tells you to roll it up in bad weather.
  • As much as we enjoy the awning at the first sign of high wind we roll it in. No use taking a chance. We also keep a close eye on the weather forecast.
  • downtheroad wrote:
    My take on this....the awning is nothing more than a sail. It will catch the wind, even the slightest breeze and will move/flap some. It's the nature of the beast.
    I stopped using clamps and tie down because I found that it slows the process of taking the awning in. If a storm comes in, I want to be able to roll up the awning as QUICKLY as possible to avoid damage.
    i.e. if it starts flapping too much, I bring it in...I don't clamp it or tie it down.
    Agree with everything here 100%. We quit using those wind-flapper and tie-downs on our last camper, exactly the same reason.
    Wind flappers cannot be put on our new Outback (electric awning), but the, "push a button" and retract is great! When wind becomes uncomfortable, "zap!" awning in! Flappers ... no need.
  • My take on this....the awning is nothing more than a sail. It will catch the wind, even the slightest breeze and will move/flap some. It's the nature of the beast.
44,049 PostsLatest Activity: Aug 31, 2025
