โMay-20-2018 01:02 PM
โMay-28-2018 08:18 PM
โMay-28-2018 08:16 PM
โMay-23-2018 06:35 AM
โMay-22-2018 02:05 PM
boogie_4wheel wrote:
To do a good job; disconnect the driveshaft and rotate the joint with your hand. Feel for stiff and/or rough movement which would indicate dry and possibly failed needle bearings. Doing this takes more time but you will find a bad joint much earlier.
If you have a two piece rear shaft, a failing center joint can cause premature carrier bearing failure (destroying the rubber support).
Climbing under the truck and twisting and shaking the shaft looking for movement will only show you an already destroyed joint. Shudder during launch because of a bad joint will likely go unnoticed when shaking the shaft by hand and looking for movement.
I just rebuilt the double cardan on the front of my dodge yesterday. Stock joints. They were still greased good, but the inside of the caps were getting dirty; 126k miles. Your joints could be fine still
โMay-22-2018 12:46 PM
โMay-21-2018 10:37 AM
โMay-21-2018 09:01 AM
โMay-20-2018 07:18 PM
โMay-20-2018 07:03 PM
โMay-20-2018 06:25 PM
โMay-20-2018 04:06 PM
midnightsadie wrote:
in the old days I,d crawl under the truck and move them up and down, and a good wiggle if theres movment they should be check. I like the ones with grease fittings. remember back when trucks ,cars had a doz grease fittings.
โMay-20-2018 02:55 PM
midnightsadie wrote:Yeah, I remember those grease fittings, and wheel bearings that had to be adjusted, and brakes that didn't work that well in the rain, and engines that were lucky to last 50,000 miles before they needed to be freshened up, and vacuum windshield wipers, and non-synchro transmissions, and manual chokes, and carburetors that required frequent adjustments, and points and condensers, and coils that shorted out when it rained, distributor caps that had to be replaced.
in the old days I,d crawl under the truck and move them up and down ,and a good wiggle if theres movment they should be check. I like the ones with grease fittings. remember back when trucks ,cars had a doz grease fittings.
โMay-20-2018 01:55 PM
โMay-20-2018 01:14 PM
