_tpc_
May 14, 2015Explorer
Using Sherline TW scale in the driveway
Ok so I just purchased one of these the other day. My plan is to try it out on the driveway at home.
I'm not so much worried about the slope of the driveway because when I go back far enough its fairly level. Additional my plan of attack would be to measure the coupler height first when attached to the truck, so that I can return to that height when measuring with the Sherline.
My issue is with the "pitch" of the driveway right to left. While up near the back of the driveway its fairly level or should I say not as severely sloped as the front of the driveway, but the side to sideleveling is pitched pretty good.
What I am thinking is that when I use the jack to raise the scale up to the coupler, the jack and scale will also be at this same "pitch". Additionally, I am thinking the extension supplied would allow the coupler to be lifted without the base of the coupler contacting the piston. So in theory, the weight measured shouldn't have a lot of "side forces" on it.
The reality is, I know it won't be "perfect", but I just won't have time to get it to a perfectly level area to really dial it in tonight. In the future yes, but not right this second.
Question is, am I wasting my time even trying to mess with it in this fashion? I just want to get an "idea". On top of this, the trailer as it sits is unloaded, and I'm loading it tonight, so the idea is to also see about how much all our gear really weighs.
Thoughts?
Thoughts?
