HandyRandy
Apr 29, 2013Explorer
Very basic question about wiring for solar
I use my TC mostly for business travel. I usually drive every day and park at night. Occasionally, I park for a couple days and a solar charging system would be great to help keep the battery charged without having to run the generator. I also occasionally stay at RV Parks for hookups. I don't need a survivalist run-for-days-only-on-solar set up. I have only one battery and limited roof space so the system will be pretty basic.
My simple question(s): Is the solar charge controller connected directly to the battery? If so, do you need to worry about the other charging sources - i.e. plugging in to AC and charging through the converter or running the generator?
Thanks for your insight,
