acudr's avatar
acudr
VSR Batt relay question
I have a northstar camper and I am changing out the vsr relay,
I thought I had it connected correctly, but not so sure now.
Camper is on the truck, and after running the truck for a short while (5 min), I was checking some other electrical issues (running lights not working) and I saw the little red light on the VSR and -1.4 amps being drawn after the truck was turned off. I put this in last month and have not checked and wondering if I did wrong.
So... I am trying to figure out how this thing should be connected and should there be any draw when the connected truck is not running. '
Where it is getting sticky is I have 2 black wires. I don't know which one should be connected to the red post. The both seem to have volts when I check each against the ground.
How do I know which is from the truck and which the camper, or am I thinking about this all wrong.
Thanks in advance.
