whjco
Jan 31, 2021Explorer
Water leak in trailer??
We have a 2019 Cherokee 274vfk and we've had it for over two years. Up until this week we've always been able to use a utility water hookup. Because of cold weather we've been using the fresh water tank and water pump.
About every 30 minutes I'll hear the water pump "burp" like it's building pressure which has me concerned that there may be a leak somewhere in the fresh water system. I've inspected the plumbing everywhere I can access it and can find no sign of a leak. There's no sign of any leaks under the travel trailer. However, we had a bad experience with a previous travel trailer that had a small leak in the shower with the water getting trapped in the insulation under the floor and we weren't aware of the leak until there was a rot problem in the floor.
I guess my next step when I get home will be to winterize the trailer by following my usual procedure of blowing out the lines with compressed air. However, I'll rig up a pressure gauge that will allow me to pressurized the system, shut off a valve with the air bottled up and then watch the gauge to see if there is a leak.
If there is a leak, what's the best way to find it?
I'm hoping that the occasional "burp" in the water pump is just a leaking check valve.
Thanks for any advice!
Bill J., Lexington, KY
