gmw_photosExplorerOct 05, 2017water pumpAnother RV wives tale de-bunked. "You'll burn out your water pump if you run it dry". You guessed it, nitwit me, left the CG this AM, drained the fresh tank and the water heater, dumped holding tan...Show More
jfkmkExplorerOct 05, 2017Yeah, you could run the pump dry. If that's the worst thing you've done rv'ing, you're in pretty good shape!
