gmw_photos's avatar
gmw_photos
water pump
Another RV wives tale de-bunked. "You'll burn out your water pump if you run it dry".
You guessed it, nitwit me, left the CG this AM, drained the fresh tank and the water heater, dumped holding tanks and hit the road. Seven hours later when I stepped inside the trailer, I saw I left the pump running.
So I filled the fresh tank here at home, turned it on, and it pumps just like it always did.
Sheesh, one more thing to add to my checklist: turn the pump off, stupid !
  • Yeah, you could run the pump dry. If that's the worst thing you've done rv'ing, you're in pretty good shape!
  • We had a mystery poltergeist when we first purchased our current camper.
    I know for a FACT when returning from the campground back home, and parking in our driveway, blocking the jacks, and plugging in, the water pumps switch was turned off as the fresh water tank was drained on the trip home.
    Alas ... poltergeist....
    This repeated over and over and over again..... two or three days later I'd go out to the camper and the switch was on and the water pump running.
    I'd flip it back off, and next day it was back on. Then it would go for a while and nothing happened. The it would do it again, very erratic, no pattern, couldn't figure it out.
    We live in the country, we do have neighbors on the next property beside us, no fences, good neighbors, so I couldn't imagine anyone nearby us pulling a stunt like this on us.
    After lots of frustration, I decided to double switch the water pump. I put a secondary switch under the bed, and simply spliced into one of the power lines feeding the pump. If either switch was off, the pump would not run. Both had to be on.
    So, when returning home, I'd flip both switches off ... and it NEVER happened again!
    I think it confused the poltergeist. To this day, I still do not know what caused it to happen.
    I have no clue how long that pump ran with no water, but I imagine sometimes it was as long as 2 or 3 days. The old pump always worked just fine. Last year I did replace it, but not for this reason, like it burned out or anything.
    Yes, they can run dry and not get hurt.
  • Yeah, hydrostatic pumps have no trouble running dry.
    I left mine running dry twice over the last 14 years. When I traded in our trailer I kept that pump and put the stock one back in. The old pump works so well that after the warranty expires on our new TT, I will install it in the new rig.
  • Never heard the 'wives tell' that dry operation would cause damage
    Pump drive head diaphragms only move 1/8", create no friction therefore no heat hence no damage when run dry
  • Stored our trailer in a Phoenix back yard for a week, leaving the water pump on.
    No damage to the water pump, but did run the battery down.
  • gmw photos wrote:
    Another RV wives tale de-bunked. "You'll burn out your water pump if you run it dry"....
    Most "RV wives tale" would be debunked if owners read the manuals.
