Marsland's avatar
Marsland
Water Tank Leak (my fault)
Well this is embarrassing :o :M ! But I need some advice on water tank repair.
This is my story. In my exuberance to make my TT more cold weather protected I dropped the underbelly (coroplast) and after checking out the tanks, connections, duct work, and everything else I proceeded to put in a layer of Reflectix. Not much more insulation but more than it had to start with.
Now the fresh water tank rests on the passenger side frame rail and extends to close to the other side. Well on the passenger side the manufacturer used short screws to attach the coroplast to the frame below the tank. I knew that :R cause I took it apart!!! But in my haste to put everything back together I forgot and used a long screw. (expletive deleted)(expletive deleted)(expletive deleted)!!!!!!
My question is (finally) can this hole in my tank be repaired with a reasonable chance of success or should I swallow hard and purchase a new tank? If it were exposed I would more than likely try to repair but being covered I don't want to unbutton everything more often than I have to.
Thanks,
Richard
