bamaboy wrote:
While I was stuck in Florida the RV was home in Texas with the slide extended when a big storm apparently hit. The good news is the surgery and subsequent radiation and chemo turned out very well. But by the time I got home the floor was rotted out. I was thinking that if I had waterproofed the floor the damage wouldn't have been as bad.
I appreciate your comments about not sealing the floor. That makes sense.
So glad to hear you recovered.
Trying to help here as I have been through slide floor rot and repaired the floor myself.
Something is not adding up to what caused the first damage. Yes, I understand a bad storm, but to rot out the floor, partly or totally takes more time then 2 to 4 months. I'm going by your words, rotted out, like large damage and the floor has a hole in it or the OSB board is disintegrated falling apart in chips.
Odds may have been, you have a leak path that has been ongoing for some time, allowing water to seep in. The big storm may have been the last straw and you noticed it.
Posting pictures of the side end walls, the underneath bottom ends of the slide, and the overall slide in general will help us see how yours is built. There has been slide construction design issues over the years. Some manufactures solved the issues, and others still build them the same way they have failed for the last 10 years.
Also, do you have a slide topper on the slide?
Are there windows in the end walls of the slide that open? (like sliding windows?)
I did not want to type a long note of how some design slides leak until we even know which design you have. The best is, know how the first slide floor failed and where the leak came from. Then make sure the cause is no longer and then treat the areas needed.
Hope this helps.
John
