egh33's avatar
egh33
Floor tile sliding
Any one having trouble with the floor tile sliding in their Motor Home?
I noticed mine is sliding from under the kitchen sink cabinet all the way to the entrance steps about a half inch so far. Of course that tile looks to be that peel and stick stuff. I guess I applied the brakes to hard and it all slid forward.Of course the coach is 10 years old, we have had it since it was brand new in 2006.
  • Floor was not cleaned before tile was put down. Pull up a tile and look.
    You will have to remove and replace. Not a hard job.
  • I don't understand how peel and stick tile can slide unless what it is stuck to is sliding.
  • phays wrote:
    The 1998 Winnebago coach I had did that. Don't think it moved as far as yours. I was able to apply pressure with my foot and move it back into position but it just slid again. I believe you are correct that it is peel and stick. Don't think there is a good solution other than pull it up, clean off the adhesive on the floor and put down new floor covering.
    It must be something that just happens to Winnebago. That's what we have is a Winnebago Adventurer.
  • The 1998 Winnebago coach I had did that. Don't think it moved as far as yours. I was able to apply pressure with my foot and move it back into position but it just slid again. I believe you are correct that it is peel and stick. Don't think there is a good solution other than pull it up, clean off the adhesive on the floor and put down new floor covering.
