anthem76's avatar
anthem76
WDH/equalizer and hitch receiver advice for newbie
We're about to purchase our first TT, an Outback 230rs. It' a toy hauler, however we're not planning on taking any motorized toys. The heaviest thing in the front "garage" will be clothes/food and occasionally, five bicycles. Our TV is a 2004 Suburban 2500 with the 8.1L and 3.73.
What type of WDH/equalizer should we get for this set up? Is this something I should get installed from the dealer, or can we buy off the net and DIY?
Also, we just bought the TV used. I've heard that the old GM receivers aren't so hot and may need replacement...any suggestions on that?
Finally, the TV has a prodigy brake thingy plugged in. Will I be able to use it with the new trailer? Sorry for all the dumb questions...our current RV is a pup, so all of this is new. We're trying to save $ on the purchase of all this stuff and the install. DH is a newbie too, but is usually pretty handy once he figures out what needs to be done.
  • Assume a loaded TT weight of 7000#.
    13% of 7000# is 910#.
    Get a WDH with a tongue weight rating of 1000#.
    Ron
  • As someone who tows with an Equalizer brand hitch, a Prodigy brake controller, and a Curt Hitch....well IMHO all 3 are excellent products.
  • We're about to purchase our first TT, an Outback 230rs. It' a toy hauler,
    They are nice but they are really travel trailers with a storage bay in the front, not a real toy hauler. Any weight you place in front will add to tongue weight, bicycles or anything else. Most toy haulers load in the rear and that tends to lighten the tongue or pin weights with the load inside. So, they tend to be tongue or pin heavy empty and ride better loaded. Yours will be almost the opposite as you add weight in the toy bay area the tongue weight will go up, not down. I have looked at the 280 TT as it is the same unit only a little bigger and like it. They are nice. But for me I need to load a large touring motorcycle and the ramp and storage area is limiting. The rear expanding bed is a cleaver design.
    Get the best hitch you can afford. In your case if you change the weight in the toy section of the TT, you are changing the tongue weight so I would opt for a hitch that can be adjusted easily to accommodate for the conditions. Spend money on a good hitch and your towing experience will be better. Get the hitch rating that will be for the TT fully loaded not empty. You might use gross weights to size your spring bars and hitch rating. The more you put in the toy section the heavier the tongue will be so this is real important not to calculate weights with the brochure weights nor the empty weights of the coach. I agree with those that think you should start with a 1200/12000 hitch and if needed work lighter by loosen a chain or leaving a washer out, etc. If you can afford to find a good used Hensley or ProPride your towing issues will be greatly minimized.
    Many of us have heard the same thing about OEM GM receivers. I would opt for a 15,000 pound or more aftermarket receiver. Curt makes one that is relatively inexpensive. Too many safety issues are riding on the hitch and receiver to be cutting corners in this important area.
    Prodigy is an excellent brake controller. Keep it if it is working properly.
  • Being a front garage TH you may have more weight up there than normal. 1,000lb bars are a good start, but 1200lb may be needed if you load too much up there.
    Dry brochure TW is 595, probably close to 700lbs when shipped with battery and propane added. Add in 5 bikes, food and clothes and your near 1,000lbs. I would start with 1200lbs and work down. You could always drop a link if your not fully loaded.
  • I agree with the post above by APT. When selecting your hitch, I would pick one with bars rated for about 200-300lbs above what the actual loaded, ready to camp hitch weight is. If you have no way of getting that number before purchasing the hitch I would add 300lbs to the brochure advertised weight and purchase a hitch rated 200-300lbs above that number. After looking up your trailer, I also agree that 1000lb bars would be appropriate.
    Barney
  • Your TV rocks, one of the best for families!
    If it still has the OEM receiver, round tube, replace it. If it is already an aftermarket, find out the make/model. I recommend this Curt one if you need a replacement. Easy to bolt on.
    The Prodigy is a great brake controller. Use it. Find the instructions on how to adjust it. They are probably the same as the current P2.
    Equal-i-zer 1000 pound is good. Call up Etrailer or RVWholesalers for good prices, about $450 shipped.
