BigfootBill
Jun 15, 2020Explorer
Weatherproofing 04 Bigfoot
First of all, thanks to all for all the info here. I read for several months before finally buying my first truck camper last week. I have ended up with an 04 Bigfoot 10.11SL as a second owner from someone who bought it new upon retirement but has had it stored away for the last several years - a barn find if you may. Based on discussion, I don't think that it was ever resealed and so I am going about addressing that.
On to the questions:
I have started with several coats of Hengs on the roof over what was there and cracking based on what I have read here.
1 - It appears that there is something similar to what I am putting on the roof on the side compartments that was "tooled" similar to what would be done with caulk. Should I try to apply a thin coat of Hengs in this location?
2 - How can I tell if the windows need to be resealed or should I just jump in and do them all for peace of mind?
3 - As a fiberglass construction, the Bigfoot design has several seams where the fiberglass meets. These joints are covered by some sort of semi flexible material that is bent over between two finishing pieces that are caulked. Should I be considering exposing these joints to reapply whatever sealant is hopefully currently doing its job?
Thanks for all of your help and guidance. The drive home was more pleasant than any trailering experience I have had and solidified that my choice was correct for my situation with a truck camper over travel trailer.
