houtrz's avatar
houtrz
Weight Distribution Hitch
I recently purchased a new travel trailer and the dealer set it up with a Husky weight distribution hitch. As per the dealer demo, they had me leave the hitch locked to the vehicle and lower the tongue jack which raises the vehicle/trailer and taking some of the load off of the bars.
Is that normal? Safe?
My other issue is when I do remove the bars, the Husky supplied tool is then lodged firmly on the ground with the weight of the weight distribution bar. I can jack up the tongue even more but this doesn't seem right. I thought about modifying the tool but have other people experienced this and what did you do?
Thanks,
Wes
  • As others said, that's normal. I had the Husky setup as well, but recently upgraded my trailer and exceeded it's capabilities. I have jacked my trailer all the way up as far as the jack will go.
    As far as the tool is concerned, I've never had an issue using it, and having it "lodged firmly on the ground" when trying to use it to remove the bars. Im not sure I can adequately describe the process in writing, but look at your hitch documentation, it will show you how to use it to remove the bars. The documentation actually has a two step process for using the tool to remove the bars. First step puts the bars on the two "tabs" that are at the edge of the L bracket on the trailer. Then you use the tool in a different position to push it off those tabs.
    Most of the time, I have been able to raise the tongue high enough to where I can just use my hands and remove bars without the tool. Depends on the setup, Im sure, and mine just happened to work out that way.
    Mike
  • Don't raise the tongue until you block the front wheels on the tow vehicle, just in case your on a slight hill and you get a bit too high. Just to be safe.
  • Terryallan wrote:
    Yep raise the tongue as high as you want. The higher you go, the easier it will be to unhook the bars. Won't hurt a thing.
    X1, I raise my trailer high enough so that the sway bars have the minimum amount
    pressure or little or no pressure.
  • Yep raise the tongue as high as you want. The higher you go, the easier it will be to unhook the bars. Won't hurt a thing.
