ScottG
Apr 11, 2020Nomad
LarryJM wrote:
Below is a post from Ron Gratz made HERE several years ago explaining specifically how both the Equal-i-zer and DC cam systems work:
The Dual Cam is a friction based anti-sway system. I discussed how it differs from the Equal-i-zer in my previous post. I do not know the magnitudes of anti-sway torques which can be generated by these two systems; but, I'm working on that.
A difference between Equal-i-zer and Dual Cam which I did not address is how the sway control affects the ability of the TV and TT to realign once they have developed a relative yaw angle. The Equal-i-zer will produce the same resisting torque whether the TT is trying to move away from the "centered" position or moving away from it. The DC, by virtue of the sloping surfaces on the ends of its WD bars will provide more resistance to moving away from center than to moving toward center. Some see this as an advantage in helping to get the vehicles realigned after a lane change, rounding a curve, etc.
The Equal-i-zer differs from a friction-bar anti-sway system in two important ways:
1) It can generate anti-sway torque directly via the trunnions and seats, and
2) It can generate much more torque.
A friction bar simply produces a tension or compression in the bar which, in turn, pushes or pulls on the ball to which the end of the bar is attached. This generates a torque on the hitch which helps to control sway.
The most commonly used friction bar has an adjustment which determines how much tension/compression it can produce. The magnitude of this is factory-set at 1100#. The center-center distance between the friction-bar ball and the main ball is 5.5". Therefore, at the factory setting, this friction bar can generate about 500 ft-lbs of torque. If you installed one of these bars on each side of the A-frame, the pair could generate about 1000 ft-lbs.
One difference between the friction-bar control and the DC and Equal-i-zer is that the friction force on the friction bar can easily be "turned off". Some people believe this is an advantage when towing in reduced-traction conditions.
Ron
You can readily see that there is NO PUSH OR FORCE in how the DC Cam system works. The cams with their slope only change the amount of "FRICTION RESISTANCE" depending on how far off the trailer is from centerline.
Larry
Well Larry, as a retired engineer I do understand how such things work and I can explain how lateral force is generated but I don't think you're open to a civil discussion about it. So, there's no reason for me to attempt to do so. We'll just have to agree to disagree.
One thing is for certain, there is absolutely no friction material employed in the DC.
Good luck to you.
44,027 PostsLatest Activity: Mar 06, 2025
