rbpru wrote:
Since I use the WD hitch to bring the TV level, I was thinking air bags would reduce the amount to bounce, perhaps making it easier on the new shocks.
not necessary to add one more calculation to your proper hitching set up formula.
this post has info for you
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24058135.cfmI agree with the people that suggested, change the shocks to BILS or 9000's . I did that, it offered a nice difference over OEM,both towing as well as solo.
I used both brands on the same truck and between the two, found no difference in ride except the dials rusted shut on the adjustable RS9000's , from road salt.
The BILS are fine for towing applications.
I have AB's as well as quick disconnect stable loads on my TV and I don't need them anymore, now that I tow. My old AB's and SL's just go along for the ride and enjoy their vacation now, they are retired until I get another TC. :)
AB's are popular on TC's to level the load while hauling opposed to towing where the spring bars do that for you.
Leave off the AB's to allow the spring bars to properly do the job they are designed to do. You will not be stressing the new shocks if you set things up correctly.
Measure the front wheel well height of your normally loaded truck before hitching up and then again hitched up with a WD system. Keep that front wheel well height as close as possible. Allow your trucks rear axle and the trailer axles carry the load.
