sportsman16
Apr 10, 2014Explorer
What does this unit weigh? Cargo capacity include water?
Trying to figure out what the as built dry weight is of a 2014 Creekside 27bh. Most trailers I have looked at have a yellow sticker listing the weight from factory as built. This unit has a sticker that states the cargo capacity should not exceed 1,094 lbs. It then cautions that a full load of water equals 666 lbs of cargo @8.3lbs/gal.
The GVWR of the trailer is 8,800.
I assumed the dry weight as built must be 8800-1,094 or 7,706 dry. This is significantly heavier that the 6,935 brochure weight.
Salesman called Outdoor RV and states that they weighed this unit at the factory and is 6,980 as built. They state that their cargo capacity sticker is after a full load of water and propane.
They claim, 8800gross
-666 water
-60 propane
-6,980 dry
= 1,094 cargo capacity
So does this thing weigh 7700 lbs or 6980 lbs? It's not that I don't trust the dealer and his call to the factory, however, I have never seen it explained like this. I thought water needed to be added against the cargo capacity?
Thoughts?
-666 water
-60 propane
-6,980 dry
Thoughts?
