- bcbigfootExplorerMy 2005 brochure says a 30c10.11sl base dry weight is 3270 lbs. or 1483 kgs. This means no options at all, not even camper jacks.
- Reddog1Explorer IIThanks for the feedback Kidoo. I thought maybe I missed something.
Wayne - KidooExplorer
Reddog1 wrote:
I was not aware of a Bigfoot with a slide, except maybe a 3500 series. Is your Bigfoot with the slide a molded fiberglass a clam shell? Do you have photos?
Wayne
It is the 3000 serie, the slide is on the driver side. The external wall is a sheet of fiberglass and the roof is like soft rubber. - John___AngelaExplorerI put a 3000 series single slide camper about that size on an F450 Dually a few years back. I tried to find the weight sheet I did at the time but i don't keep those that far . It seems to me though, with genny, air, awnings etc etc it came in dry around 4300 pounds dry. It visibly sat the dually down quite far. I think it would be overweight on a single rear wheel.
Cheers. - 54sudsExplorerthe sales brochure for 2000 says the 30c10.11 dry weight was 3040 lbs /no gen/no air /dry
2000 Bigfoot brochure
no 10.11 sl listed ? - 54sudsExplorermy 1999 BF 3000 NON slide weights 3345 with : gen and air, no liquids add aprox 300 for slide . Look in closet for more detailed equip and weights list.
- 805greggExplorerIs that the one with the slide on the drivers side, in traffic if your truck is parked against the curb?
- Reddog1Explorer III was not aware of a Bigfoot with a slide, except maybe a 3500 series. Is your Bigfoot with the slide a molded fiberglass a clam shell? Do you have photos?
Wayne
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
