Vintage465's avatar
Jun 02, 2016
What kind of mods on your trailer?
Seems to me that most of the moderately price trailers are set up for week end stints and not month long excursions. What kind of mods do you folks do to your trailer?
Since I had my trailer Ive done:
1. Built and added a storage cabinet in the bathroom. There was almost zero storage in the bathroom.
2. Built and add drawers in the pantry cabinet to aid our food storage.
3. Removed the micro-wave since we never use it. That became the coffee storage cabinet for our french press and ROK Espresso Maker & Grinders
4. Built a stow-a-way mount for the gas grill.
5. Took some 5/8"-ish glue lam type wood from Home Depot and "encased" the water tank under the tip up queen bed. I put a border all the way around it and it made a tray of sorts for the fishing poles, squeegee etc.
6. I encased the wheel well in the cabinet under the sink so I can put stuff there.
7. Made a real nice little silver wear organizer for the drawer. That Rubbermaid thing.................ahhggggg!
8 New heavy duty struts to lift the new mattress. Did a little reinforcing so the bed frame doesn't explode when the struts are compressed!
9. Added two cool little "compass lights", on each side of the bed for reading ourselves to sleep. The light the factory installed is blinding and because of the design you couldn't choose which side was on. You either got both lights or the right side.
10. Built a set of shelves and installed to the left of the frige to put our plastic wear caddy, boxed plastic wear, dog dishes and fresh fruit bowl. No stuff hanging around the dinete cushions anymore!
11. One of the last things to do is add backup lights. My wife and I have not mastered the "we stop driving at 5:00PM". Pretty tough backing into a site in the dark with no back up lights.
12. I have all the stuff to make an a couple under trailer storage tubes with aluminum caps/door-cap. One for the chairs and one for astro-turf. Just not sure I want to compromise the ground clearance.
  • I have done tons, many due to a few leaks, the major one being when I did a pee break, and forgot to turn off the pump. On rough road the cheap kitchen faucet rotated over the counter and opened up by itself. A flood resulted. First mod
    1) replace kitchen faucet
    2) Install non-locking push button in bathroom so I can use the toilet on the road without turning on the pump
    3) install leak detectors through trailer and build an electonic module to shut off the pump and city water if a leak is detected
    4) fish an hdmi cable across the trailer from the DVD player to the
    TV which was supplied with an ordinary A/V cable despite the fact both are HDMI compatible.
    5) install a sirius radio docking station and antenna on roof
    6) install an invertor to power up ac outlets when not on shore power
    7) Install aluminum runners under the slide so the Schwintek rollers can't eat into the underside (common problem with that slide) see photo
    8) Replaced the cheap suspension shackles with a Moreryde lubricated system. Here is why http://www.mexicocaravan.com/suspension.html
    9) install a rear view camera on trailer
    10) replaced mini blinds with curtains
    11) install 2 maximum capacity 6 volt batteries
    12) install Torklift Glow Steps
    13) replaced vents with powered ones
    14) install ceramic around stove top
    Now my latest water issue was a leak underneath, the insulation was soaked. Turned out to be where the drain went into the grey tank. Glad it as not the black
    It took forever to get that plastic corrugated stuff off, and it was impossible to do it without destroying it. So I have just spent a week framing in everything under there with treated 2 x 2 and installing a plywood underside with access panels to all the plumbing & wiring so I can deal with problems individually without ripping off the whole underside. Previous observation showed that water does not splash up against the underside even during heavy rain, so I used ordinary thin ply and painted it with black oil based paint. I also used foam insulation instead of fibreglass which makes a great sponge. I did stuff some fibreglass into odd shaped corners. While under there i found a retaining bracket for the grey tank that was sheared. This enabled it to shift a fraction of an inch causing my leak. They do not use ABS or PVC cement as I suppose the tank material is not compatible. They use plumbers putty and a clamp. I pushed more putty around it, then wrapped it in that tape you can repair a rad hose with, then clamped. It is not under pressure so I think it will be OK. At least I can get at it easy now.
    Its is scary how much those tanks sag.
    Oh and BTW I had an incident where my shower trap worked loose and caused a minor flood. I have now cut the floor out under that (not located over any tanks) and built a well under there. This means I can access the trap from underneath where I can get at it better and I now have a drain tube under it, just in case it happens again.
    I also have a seriously fading brown nose cap. I intend to have it painted next season in Mexico where it will cost $200 instead of $1800.
  • RavensFan24 wrote:
    GordonThree wrote:
    Most of my mods:
    10. Installed a Wilson Sleek 4G-V inside a cabinet, wired to an external marine mast cell antenna
    How's this one working out for you? I've been considering adding one of these to my trailer. I've been looking at the 4G-X though....not sure of the difference between the X and V
    It's one of the first mods I did, and I love it. There's very few places it won't pull in 3G or LTE signal, even areas where the phone or hot spot shows no service before being placed in the Sleek.
    I think upgrading to a proper antenna helps a lot too. The tiny one that comes with the sleek is designed to minimize interference in a temporary setup, and is not very powerful.
    Here's the antenna I'm using:
    Wilson Marine Dual Band
    This antenna is well made, it has survived getting hit by ice from the RV roof, that same ice shattered a much cheaper WiFi antenna also mounted to the trailer.
    The only downside to the Sleek is your phone has to be in the cradle to receive the boost. I had wanted to get a true repeater with indoor and outdoor antenna, but that's outside the budget, and with only a 20ft trailer, I think signal interference could be an issue.
    When my main phone is docked in the cradle, I either use a bluetooth headset, or use Skype on my tablet, making calls over the WiFi.
    Looks like the X is a newer version and covers more frequency bands, supporting "all carriers", where as the V focused only on the Verizon bands.
  • GordonThree wrote:
    Most of my mods:
  • Most of my mods:
    1. Added four G31 AGM batteries under the dinette
    2. Wired a "whole house" Magnum 2800 watt pure sine inverter + 125 amp charger
    3. Added 90 watts of outdoor LED flood lights for night time parking (actual watts, not incandescent equivalent)
    4. Added 180 watts of heating pads to the storage tanks
    5. Added a 12-gauge extension cord run inside the frame rail to connect the rear shore power entry to truck bed generator
    6. Insulated and added heat trace tape to sewer plumbing
    7. Insulated and added heat trace to outdoor water tubing
    8. Installed a computer controlled 12v micro pump to circulate hot water in the winter, keep tubing from freezing
    9. Removed the low end oem light weight stab jacks, replaced with 5000 lb rated BAL jacks
    11. Replaced the manual tongue jack with a Barker electric
    12. Replaced the single propane tank holder with a double tank holder
    13. Added a auto changeover propane regulator
    14. Replaced no-name radio and speakers with Pioneer unit, amplifier and subwoofer.
    15. Replaced antenna switch plate with a Winegard Sensar Pro
    16. Replaced interior incandescent with custom built ten watt LED lamps, ten total
    17. Added 40 watts of high output LED strip lights over the counter-tops and dinette
    18. not done yet...
  • Vintage465 wrote:
    Seems to me that most of the moderately price trailers are set up for week end stints and not month long excursions....
    Agreed, but even the majority of the higher priced RVs are also only intended for weekend and occasional vacation use. Few can stand up under heavy use.
    Like you I have made many mods that make our RVs more comfortable and more convenient.
    In addition to the thread already linked, here are a couple more;
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/17436377.cfm
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23032824.cfm
