joeshmoe's avatar
joeshmoe
What Removes Proflex Sealant?
So I used the CA compliant clear Proflex stuff a couple years ago. I don't recommend it. It turned a dingy color and began pulling away despite prepping the surface. So, there are bits and pieces stuck that won't come off. I'm afraid to use a harsh chemical. Tried denatured alcohol, mineral spirits. I have acetone, but I think it'll dull the fiberglass. Any suggestions?
    Can't really help with removal question but I do know that Proflex dries and remains a bit sticky which can attract dirt etc over time and is hard to wash out. Proflex RV dries without the stickiness and is what should be used. Go ahead and ask me how I know. ;)
  • donn0128 wrote:
    Careful use of a single edge razor blade.
    Did you use butyl putty tape first?
    yes, I did use tape. Used the proflex around the edges
  • deltabravo wrote:
    Bug and Tar remover is what I use. Goof Off works as well from what other people have said.
    It's time consuming to remove.
    I've used both before on the nose. Both hazed and dulled it
  • They make plastic razor blades that work great . I bought online cheap . Also craft sticks sharpened to a chisel point . Both are easy on the surface
  • Bug and Tar remover is what I use. Goof Off works as well from what other people have said.
  • Sometimes a heat gun works with a knife. Be careful with the razors, they can cut into the gel coat.
  • Careful use of a single edge razor blade.
