Wheel studs breaking
Blazing_Zippers
I change wheels and tires in spring and fall-- aggressive snow tires for winter. So far, I've broken two wheel studs while using a torque wrench to tighten the lug nuts. They both broke at about 80 ft. lbs. of torque.
I used to take the vehicles to the company that rhymes with Squab for the semi annual tire swap, but they snapped several studs using the air guns--SO I started doing the change myself.
Maybe I need to stop buying trucks from Mexico, made with steel from China???? O.K. I've vented!!!!!
18 REPLIES 18
Perrysburg_Dodg
Sorry you feel the manufacture is at fault but if that was true I'm sure we would be hearing from more then just you about this. But it's OK to vent, I vent at our know nothing engineers at work all the time :W . BTW it doesn't do me any good either!
You are going to have to replace all your studs as stated by Chris.
Don
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
jaycocamprs
^^^ what Chris said. They have all been over torqued and most will now not hold proper torque.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Me_Again
Lugs that are stretched will break later. Someone over tightened them and they all need to be replaced. Chris
Turtle_n_Peeps
Aftermarket wheels or stock?
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
