Electric traction motors will be coming and they have been available for a loooong time on Diesel/Electric locomotives
The main issue has been storage (AKA batteries) and that is now coming in. Thought Saline Batteries as they are already on line in European Telcom and always hoped Capacitor Batteries would come soon after. Exciting times for me on this area...almost too many to read up on...even the latest from China....hydrogen from a hybrid aluminum/Ceramic that all you do is add water...
The fact that a properly designed electric motor/controller/battery system can have over 300% torque at ZERO RPM is something no ICE can match. Nor can any ICE match the lower number of moving parts of a electric motor.
Issue will continue to be the upper end RPM limits of an electric vs ICE. Even vs diesel...but that is what a gear box is for and in the case for electric motor...an under-drive gear box
Pulling Hills: Torque vs. Horsepowerbenk wrote:
Posted: 11/19/12 07:29pm
Next gen American Tank will have electric motors with turbine generators
Found that out while consulting on some heat management issues
An electric motor (of the right kind) can have 100% to over 200% torque
at ZERO RPM. NO HP yet. Think of a 1 foot pipe wrench on a drive shaft
with 100 lbs of force (100 ft/lbs) but the shaft is NOT allowed to turn
That will have 100 ft/lbs torque and ZERO HP
Then allow the drive shaft to turn at whatever and NOW you have HP
Goes back to the HP formula: HP = torque x rpm / 5252
HP = 100 ft/lbs x zero RPM = 0 / 5252 = 0 (zero)
OBTW, that electric motor would make a wonderful TV motor, but I'd
have to win the Lottery in order to stuff that into my Sub...
1,500 HP continuous (duty cycle) at 4,500 RPM and about the
size of a basket ball. Plus no tranny needed, so it would fit in the
tranny tunnel to leave the engine bay for batteries (both storage
and capacitor). Diff ratio should be down in the 1:1 or maybe 1.x:1
range
Posted that several years ago: Hybrid Trucks for Towing
benk wrote:
This is the traction motor I'd love to get my hands on...or it's baby
brother, if there is one...
High Torque Density Traction Motor
1,500 HP...CONTINUOUS duty cycle next gen tank motor and it will have TWO of them.
One on each side (treads) and direct drive on the sprocket. Plus these
can be over driven to have over 200% torque at ZERO RPM at a reduced
duty cycle (think somewhere around 40%....also assuming dependent
on the cooling systems capabilities)
On our trucks, NO tranny needed and the diff can be a 1:1
Since no tranny, this motor can be in the tranny tunnel and the ICE bay a pure
generator & battery setup....also tried to get a few of the OEMs
to understand that architecture, but they have no clue in their
marketing and management folks....their engineering folks did and
loved talking shop with them...but the decision makers continued to
give us headaches...
Glad to find you also understand that any 'diesel' locomotive is a hybrid and
has been for decades. I'm working on my city's staff trying to get them to
understand that and that the freight line can be an all electric for HSR (high
speed rail), but that is another topic...
