Buzzcut1's avatar
Buzzcut1
Nomad II
Apr 29, 2018
Why didn't I do this sooner?
I always hated the cabinet latches on my Lance. Any big bump and you were more than likey going to find the cabinet open and stuff on the floor. I had one break and I installed a push/pull latch before the last trip. the cabinet stayed shut down one heck of a pothole road. I spent an hour today removing all the old latches and installing the new ones. Nothing to push just grab and pull. the cut out for the old latch makes for a perfect handle. I stll lef the hooks i put in on the cabinets that have pots and pans or breakables. It took less than 5 minutes per latch to install. $11.69 per latch at Camping World
  • I totally dislike plastic anything!! I replaced those plastic latches on the drawers of my motorhome with brass ball catches. Plastic catches broke within 6 months of being new.
  • Is that on 2008 Lance?
    I prize my 2002 Lance for excelent cabinet latches, so did they cut corners in following years?
    Not only rock-solid, but push button on the side make perfect cosmetics.
  • Mine have never broken. Might be what you are carrying.
  • and they break every couple of years..
    I've had replace several them already on my Host.
  • These latches are about half that price at McMaster. Without the "RV" markup....and available in 3, 5, and 10 lb pull.
  • Thanks for posting about your latch upgrade. I'll keep them in mind if needed in the future.
  • Good job..I need to do the exact same thing..My so called hidden latches need to be replaced..They work okay but there are better choices out there now.
  • there on e bay about $4.bucks each takes two screws to change out. used them for tears work great.
