- Griz14Explorer
Griz14 wrote:
deltabravo wrote:
Is this an antenna without any boost of the signal?Griz14 wrote:
What makes a good Wi-Fi Booster and Range Extender that doesn't require mounting it on the roof?
I've been using this since 2011.
There are better things available now, but this works for my needs. - Griz14Explorer
There are better things available now, but this works for my needs. Griz14 wrote:
There are better things available now, but this works for my needs.- traviscExplorerThose really are two separate devices/ solutions if you want to do it right. We did weboost drive x for the cell and still working on the WiFi solution
- rhagfoExplorer III
Griz14 wrote:
time2roll wrote:
Are you trying to boost the campground signal? If so I doubt a booster will help your connection.
Or are you trying to better broadcast your own signal?
Yes I am trying to pick up the campground Wi-Fi signal and boost it to my laptop better.
Save your money, get a good cellular hot spot and find the best data plan available. Using your phone as a hot Spot will give less than good service, a dedicated hot spot is much better. - MitchF150Explorer IIIWhy anyone would connect to the "free" wifi in a campground and expect any kind of speed, other than "maybe" google or yahoo is beyond me...
It ain't like you are going to be able to login into your Netflix account and stream movies all night long! ha, ha...
Not to mention, the security risk in tapping into those 'free' wifi sites at restaurants and such... Even with a VPN, you are more at risk if you feel safe doing that..
Anyway, get a data plan for your phone or a "mifi" device or something...
Don't rely on those 'free' wifi spots.. Just asking for trouble and you won't get any speed anyway, no matter how many "booster" you have.... :)
Good luck! Mitch - Big_KatunaExplorer IIPoor, slow wifi is the norm these days. A booster won’t improve a poor network.
I have pretty much given up on good wifi and went with a Weboost cell booster.
I have iPhones on Verizon with umlimited data we turn into a hotspot AND I bought an ATT based hotspot data only puck which I turn on a month at a time if Verizon doesn’t fill the bill.
This works good enough to stream HD content. - Griz14Explorer
Yes I am trying to pick up the campground Wi-Fi signal and boost it to my laptop better. - Are you trying to boost the campground signal? If so I doubt a booster will help your connection.
Or are you trying to better broadcast your own signal? - wanderingaimlesExplorerAnd if you are going to look at non wifi, check your cellphone and plan. using a smartphone as a hotspot has become more or less standard.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
