- samuraiownerExplorerI use the biggest one sears makes and run it constant when the tempature go's below about 40 deg. but I full time in A 5th wheel and go camping with a truck camper
- bka0721Explorer IINo, I don't use one.
If you read the instructions of many of them, you will find that they will not work in areas such as a Tuck Camper. They are mostly designed for use in areas such as closets or cabinets.
The biggest producer of condensation is human caused, Breathing. Cutting down on this is not recommended. Also, the longer your vehicle is occupied, the more the condensation is amplified. The reason most TC users don't experience this issue is they refrain from really cold weather and extended periods of occupancy. I often compare this to a dripping faucet. For weekend use, the faucet turns off when you park and leave it. With those that use it for mutiple days, the dripping will continue.
Minimizing condensation is an important factor, cracking a window will not do this alone. Try to cook outside, when possible, especially water saturated foods, such as boiled items, like vegetables, pasta and the such. Dry out wet and snow soaked items outside of the occupied areas (including bathrooms). Limit showering during the winter, or do it earlier in the day, to allow the water vapor to dissipate as activity continues and outside doors open and close. This includes wet towels by drying them outside the camper or the cab of the truck.
Use towels to wipe down the walls, inside cabinets, windows and window tracks and dry these towels outside during the day. I keep one in a ziplock back next to my bed, to wipe things down during the night/morning, then set outside to dry.
Last by probably the most important, distance any organic (clothing/bedding) material away from outside walls. These will wick moisture into these items and start mold. It is that musty smell, often associated with damp basements. This can be a health issue for some. Each winter, I remove all clothing from cabinets and drawers, storing them in stuff bags and sleeping bag stuff bags.
No matter if you use a Dehumidifier, you will still need to take steps to counter condensation, within a confined area. Insulating the windows will not stop condensation. But will minimize it from those surfaces. Condensation will just find other places to condense, when these window and cold surfaces are not available to collect the moisture in one place.
Winter camping has it downside, but the plusses far outweigh these immensely. With a little bit of technique and preparation, this can be accomplished.
OP, yes, you just asked about a dehumidifier, but this is a good place to share tips for others to try venturing out durning the "Winter Season."
b - sabconsultingExplorerWinter camping in my damp climate condensation is a problem - mainly on aluminum window frames, the single-pane glass windows themselves and the metal frame of the escape hatch, plus the huge plastic moon roof (something some of the hard-side Shadow Cruisers had). All these things act as heat sinks and become cold enough for moisture to condense out onto them. Especially since we are often bringing wet clothing into the camper, plus boiling water in the kettle and heating food using the gas stove.
In winter we always camp with hookup so I've started bringing along a portable de-humidifier. It is a bit noisy, but less so than aircon, but it does strip the moisture from the air. Although it is a slow process - it won't dry out the camper in minutes, but it does help a lot. You need to keep the camper heated when running the de-humidifier though.
Steve. - SugarHillCTDExplorer
jimh425 wrote:
I use an electric heater when possible. It doesn't put moisture into the air like propane does.
I hope the only moisture you get from propane is from the stove. Otherwise your furnace exhaust is exiting into the camper :E - jimh406Explorer IIII use an electric heater when possible. It doesn't put moisture into the air like propane does.
- brholtExplorer IIWhen camping I usually:
1. Have a very small amount of ventilation.
2. Have a couple of these along.
Rechargeable moisture adsorption units
When done camping I usually run an electric dehumidifier for awhile to remove residual moisture from the camper. I'm not really sure which of these steps is most important but we don't seem to have a lot of problems winter camping over the weekends here in the Pacidfic Northwest where, needless to say, it is usually very damp and cool. - RoyBExplorer IIWe have camped alot in the late camping seasons and do get some inside moisture on the windows and sometimes water dripping off the inside of the tent bed ends metal supports.
Usually all we need to do is make sure we have a fan running inside the trailer.
Never used a dehumidifier before. That would probably help but since most of our camping is off the batteries and inverter that would just be another 120VAC items we would have to deal with...
Roy Ken - RWjSIM2003ExplorerWe are using one I picked up at Home Depot in October. Think it is a sunbeam works great can be set to different levels and runs on auto. It does a great job here in the PNW.
About Travel Trailer Group
44,025 PostsLatest Activity: Feb 06, 2025
