canoe_on_top
Oct 11, 2013Explorer
Opening low point drains may not drain your HWH unless you release the pressure relief valve. Probably best to pull the drain plug then you get the water out and much of the sludge and can check your anode rod if you have one.
44,026 PostsLatest Activity: Feb 24, 2025
