covered_wagon
Jan 11, 2015Explorer
If you search 'wire reinforced corrugated hose' The correct connection is to use 3M 5200 inside the hose before it's slipped on and clamped. That is because the corrugated surface makes uneven pressure around the connection form the uneven surface. My Northern Lite, brand new, also did not do this correctly and I had a big leak from that.
I don't think any manufacturer is properly connecting the corrugated water fill hose.
44,026 PostsLatest Activity: Feb 24, 2025
