Dodgemahal's avatar
Dodgemahal
Jan 14, 2024
31 below zero, RV antifreeze failed?
I see the forum format has changed since I have posted last.   I have a 2005 Bigfoot 9.6 truck camper.  The camper is covered and  is under a carport with an open front.  I winterize it every year with RV antifreeze.  I live in the Northern Idaho panhandle. This cold snap many people are seeing has hit me also. Last night it got down to -31 degrees below zero.  15 below is not unusual here. While making rounds to the shops and camper this morning I found that the 3 remaining unopened gallons of Camco RV and marine antifreeze rated to -50 below that I had on the shelf were frozen. At the time of finding this it was -9 below. I had intended to dump some down the toilet into the tank just in case. Looking in the camper the lines were also frozen.  The toilet valve was also stuck and frozen.  Naturally I got a little upset. I put a heater in the camper and it is still running now.  Has anyone seen this happen to their antifreeze in extreme cold weather?  I spoke to a friend about it, he talked with an acquaintance who winterizes dozens of boats in the Seattle area with the same stuff.  His friend said it can freeze but it is designed to not expand and break things. I looked and nothing looks broken. But I will know more later when temps rise.  From now on I am pushing the antifreeze out with 10 PSI of air to vacate the lines in my fall procedure.   I just wonder if anyone has any known experience with this problem or knows something I don't.  It still bothers me that it was supposed to be rated to -50.  Please see the picture of the new jug on it's side and nothing is fluid. It is solid. Thank you.
  • I have been doing this for many years and we have had great results. Completely drain the water from your rv using the low point drains, then use the bypass to pump rv antifreeze into the lines, faucets etc. After that drain the rv antifreeze using the same process you did before. I catch the draining antifreeze and use it in my black tank for a little extra. No air compressor needed.
    Following this procedure we have almost no (I said almost) smell, and it is easy to rinse the pink out of the system since there's not much left. I should add that I bypass the water heater first and never put any rv antifreeze in the fresh tank. It makes it very easy in the spring when I want to use the 5th wheel. My biggest concern for people that use air to blow out the lines is how do you flush the water pump?
    My belief is that with not leaving the rv antifreeze in the lines all winter the smell doesn't get into the lines nearly as much. Plus the last thing in the lines was the antifreeze so even if it collects in a low spot nothing will get damaged. Trust me, with my luck there would be a plastic fitting that was the low spot and it would break! I do have pex lines, but the fittings aren't and I am not taking a chance with them. 😉
  • I have lived in Alaska for now going on 42 years....
    As far as any type of antifreeze is concerned - I would tend to use my antifreeze tester to see what the TRUE concentration reading shows - mixing 65% Prestone antifreeze with 35% distilled water will actually show a different reading then using the same mixture 2/3rds antifreeze-1/3rd water with the Peak brand....just by looking at RV antifreeze itself with a label rated past -50 below F I laugh and say no -way ! as I lived in the arctic for too long - and I am a native southern Californian !
    I never used any kind of RV antifreeze for my cabover for outside winter storage, as I simplify any RV life I ever get (only up to one month a year as I still am a working stiff) so I just never use the sink or toilet to begin with - as I purchased a portable toilet for the girls, and use my own honey bucket with a lid and a removable toilet seat to boot along with using a couple of Prestone jugs for #1 nature calls if I am not in the wilderness or a nearby rest stop or bathroom facility.
  • Not to push where I work, but here is an online article that should help you understand the ratings a bit better.
    In a nutshell, the rating you use, ie -50, is what that version will burst a copper pipe at! BUT some will actually freeze at say 10-20F temp. So, what your gallons you have, have done, is normal! Froze, but have not expanded to burst your pipes!
    The client I mentioned wanted the wintersafe, vs std -50. As you can see in the article, the wintersafe went solid before the std -50. Which is what the client found when he put some in their freezer! I work in the wholesale side of things. We sell 300-400 55 gal drums to various boat dealers getting them prepped for winter use. Ranger Tug buys this stuff to put in waterlines for boats leaving the area to other places from October to March. We ship 10-15 pallets with 4 drums per to a place in Alaska too.
    If you are near the WM in Spokane, they should be stocking the -50 or -100. Or it can be shipped to you next fall. The minus 100 might be a better option based on temps you are having from an additional safety standpoint. Our brand is made by Starbright, you might find places with that brand, or another companies version, made by starbright cheaper if you hunt around. At $5-8 per gal with a quick online search, shopping at multiple places will not save you a lot per say, if you only need a few gallons. A 55 gal drum might be another issue at $350-400+ per barrel!
    Here is a link to article, it's time to go to bed, did not realize it is so early in the AM! LOL
    How to Choose Antifreeze for Your Boat Engine | West Marine
    Marty
  • I work for a marine supplier. Had one of the places say they wanted X type of AF as it supposedly only turned to slush. So it would not damage the boats motors! Much more expensive than waterlines in RV's. They put a cup of both the stuff they preferred, and one that we sell about 100 to one vs what they wanted. The one sold the most, was actually softer than the one they wanted, and a bit cheaper too.
    At the end, both work well. Granted we only usually have temps in Puget Sound into the 20F relm, had a few pushing 5-10F around here in the last week.
    Another buyer will only use -100 as they think it will protect them more from cracking motors.
    Reality, if the AF freezes per say, but does not expand, it is not an issue for anyone, whether you put it into an engine cooling system, or the water lines.
    Just make sure you use the types for waterlines that are not poisonous to you  or other animals if you dump it on the ground after use, or in the case of a trailer able boat motor, when you turn on the system in the water, it will not hurt the water you are in.
    Marty
    • Dodgemahal's avatar
      Dodgemahal
      I have only used RV antifreeze. I flush it out, fill the system and let it soak. Then run it to flush the leaching out. And repeat that at least two or three times before heading out camping with a fresh tank of water. I also have a very high quality 3M water filter under my sink with a dedicated touch flow faucet. As a back up only as I don't really drink out if it because I always bring a LOT of fresh well water from home in SS jugs. I used to work at Intel in Oregon in water purification (wafer fab water seeks what it lacks and becomes  a solvent) and acid waste neutralization. I can say with accuracy that I am a water snob.  I avoid tap water in cities unless it is filtered. I have full knowledge what they do to it to give it back to the population.  I also don't want to ever ingest left over residual propylene glycol from RV antifreeze because despite saying it is safe, that is a bunch of hooey.  I am very conscious of clean real food and clean water.  And if there was a quick way to winterize my camper without the antifreeze, I would do it. But there is not and the extensive repeated flushing in the spring I think helps get rid of it.  I can't smell much anymore thanks to covid x3 and I really want to make sure I am bathing in clean water.   Honestly that is about all I use it for.  I am sure ready for summer and sitting by a river.   Or a nice camp fire.  That would sure do right about now.    Thank you for your post.  It was interesting and informative.  I did not know they made -100 stuff.. wow ,  Thank you Marty, Cheers,   Al
  • After using the antifreeze and having it turn to slush, in the following years I would blow it out of the lines using compressed air after adding it to all lines. You have to lower the pressure when doing this. Nothing left to freeze this way.
      Dodgemahal
      I had considered building the air purge system the last two years. Life got in the way as you can see from my signature and I did not do it. But trust me it will get done for next year and every year after that for as long as I own the Bigfoot. I have more of a solid than slush.  I never looked before. It was do the antifreeze flush and cover the thing and find the plow truck.  I never liked the residual smell from the antifreeze anyway.  Besides, I really like building things to make something better.  And this is a perfect opportunity.  Thank you and thank you to everyone who helped settle my worries.
  • I use rv antifreeze, but I don't really trust it to get into every inch of pipe, valves, etc in our Lance.  Its going down to 5 degf here tonight in Alabama and I will have the camper heat running to keep the camper about 55 degf.  Probably overkill but its cheap insurance and I will sleep well. 🙂
    I did a couple of tests a few years back by putting a cup of rv antifreeze in our freezer.  IIRC it went down to about -2 degf.  The antifreeze turned to slush, but never froze solid.
    bradw
    • Bedlam's avatar
      Bedlam
      Moderator
      Remember that it does not need to be bone dry to winterize. You only need to blow out the majority of water so that if any remaining freezes, it has a place to expand. I typically set my compressor regulator to 50 psi to prevent over pressurizing the system and do my rounds between faucets and low points until nothing but air comes out. The order you do the blow out depends on the routing of your plumbing and after a couple times doing it will reveal a pattern that works well for your camper.
  • Well I guess I got caught off guard with it being a solid.  No the frozen jug is not bulging.  I had never looked in past years and it was always fine in the spring.  I am going to build a small air flush out of an old small compressed air tank. I will put a regulator and ball valve on it for a low pressure push. I had thought about this before because I don't like how long it takes to get the left over smell out.  I have a detailed winterization process. Draining the fresh into a tub to toss outside, filling P traps, faucets open etc. It is a great camper in like new condition. I just want to keep it that way.  I appreciate the responses.  You never stop learning.
    • mkirsch's avatar
      mkirsch
      Nomad II
      If you have an empty jug fill it with water and put it outside, just to prove the difference to yourself and give yourself some peace of mind for the future.
      When that jug freezes it will be so bulged it won't even stand upright anymore.
        Dodgemahal
        Well I beat you to the suggestion. I left this water bottle in the truck overnight.  I guess I won't be using that one anymore.  LOL   Yes well aware of the power of ice. I have repaired many PVC pipes shattered from a solid freeze.  The good thing is the Bigfoot looks like it has pex in it.  That stuff handles freezing pretty well usually.  It is has Rv antifreeze in it. It was always fine at each spring thaw. I had never looked till this years 31 below.  Have a look at the picture... Oops.
  • Once you drain and blow things out, you will probably want to put some antifreeze down drains to protect from freezing of the water in P-traps (won't drain or blow out).
  • Yeah, the trick here is that it doesn't expand and break things when it freezes. Assuming you got all the water out before you put the antifreeze in, your rig shouldn't be damaged. Water is actually unusual in that unlike most things, it doesn't shrink when freezing, it expands, which is what breaks things.
  • While some types of RV anti-freeze are better than others, most will turn to slush or freeze at extreme temps. It should not expand, cause any damage. I normally open low point drains, after using anti-freeze in Fall, and blow most out. It will be mostly pure, so I dump the small bucket of used AF down the toilet, to keep some liquid in black tank.
    You should be fine come Spring, when you flush your system.
    • Bedlam's avatar
      Bedlam
      Moderator
      I also blow out lines and only use the anti freeze in the p-traps. I leave all faucets and drains open until ready to refill with water. This is a regular process for me in the winter since we go out twice month rain, shine, snow or ice.
      • deserteagle56's avatar
        deserteagle56
        I must be doing something wrong...twice now I've tried just blowing out the water lines on my Bigfoot and using antifreeze only in the p-traps.  Both times there was enough water left somewhere in the system that it was frozen and I had to put heat in the camper until it thawed.  Condensation, maybe, as it was a few months before the camper was used?  So I've gone back to pumping the RV antifreeze through the lines and then flushing everything when I've ready use the camper.
