โSep-14-2024 12:40 PM
Iโve been using the Torklift Fast guns on my truck camper for the past 11 years, but the camper has aged so has the tie down points. I really donโt feel comfortable putting the downward pressure the Torklift tie downs inflict on the camper, I think they say, properly adjusted its a 300 lb force on each corner. I am starting to see the tie down point sag ever so slightly under that pressure. 300 lbs of force seems a bit excessive to me.
Do the Happi Jack tie-downs exert less? Can the threaded rods on the TL Fastguns be used in the HappiJac tie down bodies?
Thanks,
Mr. E
โSep-16-2024 01:26 PM
Similar to other responses, if youโre worried about tightening up your tie downs, the problem isnโt with the tiedowns.
Never even considered the actual tension force. Just good n snug, ie just snug enough to keep the camper from sliding around.
Either fix the camper or ease up on the tension, until it moves on you and tighten up a bit more from there.
โSep-17-2024 10:29 AM
Thanks for all your valuable input. i addressed beefing up the camper to tie down connection by having a steel plate welded to the tie down points that I then drilled holes through and inserted toggle bolts through the bottom of the camper. This way any force is distributed over a much wider area. I agree with Grit-dog, I just make sure they are snug and check them now and again. looks to be workingโฆ. Again, thanks for your responses, much appreciated.
โSep-17-2024 01:52 PM
You will find keeping even tension on all four turnbuckles reduces your camper from shifting. There will still be those washboard roads with a high crown that cause chaos, but much less when each camper corner is equally secured.
โSep-15-2024 08:21 AM
The tie downs are supposed to keep the camper in place, even in an emergency situation. If the camper structure is too soft to anchor it down safely, I would be more worried about the camper than the tiedowns.
Personally, I don't think switching over to the Happijac tiedowns will make a difference.
โSep-15-2024 07:25 AM
I'll agree with @MORSNOW if 300lbs of force is causing an issue then the fast guns are not the issue, I probably get closer to 4-500 lbs with my bottle screw tie downs. if you think about it your stopping a 3000+ lb object from shifting around in your truck bed. find out why its flexing and see if that is an issue or not. if not your done, if it is an issue then you have to figure out how to fix it.
โSep-15-2024 05:39 AM
If the anchor points are pulling out of the camper, you need to address that issue, not the Fastguns. You may have rot in the camper where the anchors are attached that needs to be repaired/replaced.
